Franklin CWP-206 Logo
Posted on Dec 07, 2009
Need a new copy - Franklin CWP-206
Can not get xp to reload on to new drive
Check the disk for scratchs and scuffs. It sounds like your disk has been damanged. If you have access to a computer with a CD burner you might try to make a copy of your disk, sometimes even a damanged disk can be copied. If this works, then use the copied disk in the computer to install XP. If not you will need a new XP disk.
tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 • Computers & Internet
tip
Backup or Copy 2009 DVD Movie on Mac OS in holiday
2009 has been past, 2010 is Coming!
2009 is wonderful, and so are 2009 Movies! There are so many excellent movies that we can enjoy them in Xmas holiday. Want to Backup DVD movie or Share Movies with Family and Friends?
We need a cool software which can help us copy DVD movies on mac, I think some third party softwares will be a better choice than Disk Utility.
Just like Mac DVD Copy Pro which is specially designed for Mac OS X users to lets you Backup DVD Movie on Mac with just a few clicks. It also allows you to output DVD folder and directly burn DVD Movie on Mac to new DVD discs.
Step 1: Open Mac DVD Copy Pro and Insert DVD Movie need to be backuped.
These Movies can be Sunmmer Movies or Christmas Movies, such as Transformers 2, Harry Potter and the Half-Blood Prince, 2012, Twilight, The Twilight Saga: New Moon, A Christmas Carol and so on.
Step 2: Select DVD Copy Method
After inserting DVD, the main interface will turn around. And you can see the DVD whole contents in the menu list. If you insert DVD9 disc, you can choose the D9 to D5 compression option to compress DVD9 disc to DVD5. You can choose Main Movie Copy, Customized Copy or Full Copy from Copy Options according to your needs.
With the help of Mac DVD Copy Pro, you can Backup these DVD Movies to ISO Files, Video_TS or .DVDMedia files on Mac OS X, even on Mac OS Snow Leopard. You also have the choice to backup the above three formats to your external hard drive.
After simple tips, click Start button to begin burning.
Step 3: Finish the DVD Settings
After clicking ?start? button, you need to type in the DVD name for the new disc. And you also need to choose optical driver to burn the disc if there is more than one driver. You can also choose the copy speed and quantity according to your own need.
Step 4: Start Copying DVD Movies
When the setting finished, DVD Copy Pro will start burning DVD and save the data to a temperate file. After burning, the program starts encoding DVD and will inform you to insert a suitable blank DVD disc.
Now you can share DVD movies with friends or watch them on Mac and DVD player in the New Year holiday.
on Jan 11, 2010 • Computers & Internet
I NEED TO TRANSFER THINGS FROM ONE COMPUTER TO A NEW COMPUTER I DON'T WANT TO MOVE EVERYTHING JUST CERTAIN THINGS LIKE MY PICTURES AND DIFFERENT DOCUMENTS THAT I DO NOT WANT TO LOOSE
Hi sks846
Create a new folder in the old computer , rename it ( " old computer documents " or whatever you wish ) and copy your selected files to it . Copy the completed folder to your flash drive . Disconnect the flashdrive and connect it to the new computer . Copy the content to the new computer . Copy of your documents are now saved on both the flash drive and the new computer . You are now 100 % safe . If necessary , the originals can be found back on the old computer .
Best regards ,
fanaudi .
1helpful
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
1helpful
I need to copy all my contacts from my w910i onto a new sim card and I don't know how to
sir please go to the contacts option rightclick and select the options next to the advanced option in this first select the copy from sim.your simcard contacts are copy to the phone.now you insert the new simcard.go to the advanced option and now select the copy to sim option.so that you can copy the old simcard contacts to the new simcard.....................
1helpful
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
How do I copy macros in word 2007 from one
1. Just search for 'Normal.dot' file in your old Computer containing you macro. Copy it..
2. Now search for the same file in your new Computer and replace it with your old Computer's file.
3. Copy Normal.dot from old to new computer and you are done.
Good Luck!!!!!!!!!!!!!!!!
Printer has not been used for 2 yrs. I use it to make copies.
I'm sorry. The printer needs both cartridges (which holds the ink) and printheads (which distributes the ink) as well as the scanner to copy a page for you, since even copying is a print job.
//Al
2answers
Registration of DVD X Copy Platium
Unless your copy is "bootlegged", simply call the company and tell them the old computer crashed several times, you gave up, bought a new computer, and you need to install it on your "new" computer.
If they value you as a customer they will give you support you need, if not make sure you tell them you are taking your business elsewhere.
You may need to buy a new license because you under the old license it only allows so many activations. But at least try to get a "freebie" anyway.
Top Franklin Office Equipment & Supplies Experts
nexrad_chris
Arnie Burke
Arnie Burke
k24674
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
