Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo paper 100 sheets high gloss 4x6 cat 850 5141.
Posted by Charles Walker on
Anonymous
  • 295 Answers
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Posted on Dec 10, 2009
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
We have an HP color laserjet 3500 printer; we want to print 4x6 paper; how do we do this?
You will need to feed the paper through the manual tray and you will need to set the paper size in the driver for 4X6.
Apr 27, 2011 | HP Color LaserJet 3500 Printer
Kodak 6850 how do I print 4x6 on 6x8 paper without huge white border... now that you cant buy 4x6 media ?r
the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nov 22, 2010 | Kodak Photo Printer 6850 Thermal
4x6 glossy postcards feed through slipping
Make sure that the paper meets the specifications for use in your printer.
The paper you are trying to use may be to heavy to be moved correctly through the paper path.
Don
Feb 25, 2010 | HP LaserJet 4200 Printer
How to set for 4x6 photos
Nothing special to set for 4x6, you lust slide the paper guide over to the 4x6 paper and stand the paper up in the paper slot in the back. You have to choose 4x6 print in your printing software window in printing preferences.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Trouble feeding paper into printer
call our technician on toll free no 18884276640
Jun 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
HP Photosmart 3210xi All in one printer will not print 4x6 photos
Have you processed many print jobs through this printer? if so, you might be needed a maintenance kit. the kit will include new rollers that will help pull the paper into the proper feed paths.
Apr 30, 2008 | HP Photosmart 3210 Printer
Printing
seems that y´all experiencing various paper feeding issues
check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s
and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
Dec 24, 2007 | Epson Stylus Photo R320 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
278 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Muntejaya Ginting
Muntejaya Ginting
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
