Question about Dryers
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
I have a Maytag Performa Model# PAV 2300 AWW washer and during washing cycle if it's washing load larger than ''large'', the agitator would become detached to the washer but doesn't affect the spinning. The agitator is attached to the bottom plate by a bolt and I can reattach it by using a ruler and packing tape at the end. Problem is that it keeps on happening. Is there a way of making sure it stays on so this process doesn't continue?
  • 1,891 Answers
Pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Posted on Dec 08, 2009
6ya staff
SOURCE:
I have taken my Maytag Performa PAV 3300AGW top loader washing machine apart after grinding noises were comming from the machine. After removing the drive pully mechanism from the agitator shaft I dis
This should fix you up nicely:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-PAV3300AGW/3048/0153200/M0604157/00004?blt=06&prst=&shdMod=
Good Luck.
Jan 04, 2013 | Maytag Washing Machines
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Agitator screw keeps coming out.
New parts !!
Threads are worn and will not lock
Apr 01, 2010 | Maytag Performa PAV2200
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
Maytag top load washing machine model PAV 2300 AWW. I've put in new springs but washing machine gets out of balance very easily. Have you got any suggestions?
If you have replaced the spring is the tub over to one side not in the center of the hole there is what they call a snumber ring on the bottom of the base the washer sets on that could be wore out but it is really hard to replace and you will need a special tool to compress the break
Apr 11, 2009 | Maytag Washing Machines
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
I HAVE A 6 YR. OLD MAYTAG PERFORMA PAV 2300 TOP LOADING WASHER. UNIT WORKS FINE EXCEPT FOR LOUD CLUNKING NOISE AFTER SPIN CYCLE. NOTE - ALL BRAKE COMPONENTS HAVE BEEN REPLACED.
It sounds like a spn down noise. I would check to see if the brake spring was changed when the brake and stator was. They had some problems with weak springs.
Apr 24, 2008 | Washing Machines
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
245 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
