Question about Dell Vostro 1000 Laptop
My dell vostro 1000 won't turn on the green light
My dell vostro 1000 laptop won't boot up the green power light comes on it makes a noise like it's gonna come on but does nothing ta sj
Posted by sandmplumbin on
Anonymous
    Sergeant:
  • 244 Answers
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Posted on Dec 09, 2009
  • ddoherty662 Mar 01, 2011
    Two dell vostro 1000's with the same issueand it has turned out tobe the CPU that has failed.
I press my power button on and nothing comes on the screen. My screen is black as if it wasn't on. Please help me I have a Dell VOSTRO 1000
does a light come on when you press the power button? Remove the battery then just use the power adapter.Then check the cables of your power adapter if it is connected properly. Try unplugging and replugging the cable at the back of your laptop. Make sure that on the the power adapter ( the small rectangular boxlike) has a green light. Then try pressing the power button again.
Sep 22, 2010 | Computers & Internet
Dell vostro 1000 laptop power problem.when you plug in the power supply before its plugged into the computer the green lite is onwhen you plug the adapter into the laptop the light goes out and there...
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
Jan 30, 2018 | Dell Vostro 1000 Laptop
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Booting problem
Unfortunately blinking Caps Lock light on Dell laptops means faulty motherboard. If laptop still under warranty, then bring it back to Dell.
Sep 04, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 will not boot.
It maybe the power adaptor is loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Failure to power up
Check the cable and do power on self test(POST)
Aug 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Batt light flashes 4 red and 1 green over and over vostros laptop
Hi there. If your battery light is flashing 4 red and one green on the battery light indicator (as in the one next to the power and hdd led), then this is an indication that your battery is nearing the end of it's life, and it's time to get a new one. It will last a bit longer, depending on how much you use your laptop, but there will come a time when it won't work at all.
Tim
Apr 20, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 Laptop Logo
1,189 people viewed this question
Ekse
Thomas F. Schneider
Joel Rodriguez
Joel Rodriguez
