Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Flashing red light and bleep noise and now it wont chill
Posted by mhairi_gunni on
Anonymous
    Problem Solver:
  • 7 Answers
Needs a new thermostat
Posted on Dec 07, 2009
  • nhodge882 Sep 08, 2011
    Not true at all you could have lost your refrigerant or the compressor could be at faultly. Best call an engineer
Anonymous
    New Friend:
I have the same problem with this model, is it a common fault? the freezer is only 3 years old!!!
Posted on Dec 27, 2009
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Power is on but don't run
Is the red light flashing if so count the #of flashes it shows consecutively.then Google that #of flashes on that model you will get your answers. If just solid red you may have an issue in the board or compressor
Aug 11, 2014 | Haier Freezers
Freezer wont freeze beyond a chill. Please Help
Sorry to say that this happens a lot. More then likely there is a refrigerant leak and the place you bought it from had it charged right before you saw it. That is why it worked then, but not when you reached your destination.
Jul 09, 2010 | Freezers
Red light and buzzer
it is telling you your freezer isnt cold enough
May 04, 2009 | Candy Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
1,808 people viewed this question
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
