Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Getting white streaks on black and color horizontally. km bizhub c352p mostly on screens, somewhat on solids.
Posted by advprint on
mike roark
  • Konica Minolta Expert
  • 158 Answers
Sounds like you will need to have the transfer belt replaced. all images are developed on the four drums then transfered to the transfer belt then to the paper so if the image problem is coming out on all colors and black an white then the best bet would be to replace the transfer belt
Posted on Dec 08, 2009
I have a KM bizhub c 451 black imaging unit that prints faintly. I have replaced the following parts, PC drum, PC charger and starter( developer), yet it is not printing solid black.
replace the black image unit as a whole you do not replace the units as individual parts. Where did you get the drum from? or the PC charger as they come as one and you don't replace the developer as it is located inside the unit!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 22, 2017 | Konica Minolta Bizhub C451 Copier Print...
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
My printer is running a white streak through the center of pages
You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
214 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
