Question about Texas Instruments TI-30XA Calculator
How do i enter pH on a TI 30 calculator - Texas Instruments TI-30XA Calculator
Posted by christinatho on
k24674
  • Texas Instru... Master
  • 8,091 Answers
This post answers two questions
  1. How to obtain the concentration knowing the pH?
  2. How to obtain the pH knowing the concentration
If you are not interested in the theory, jump to the examples at the end of the post.
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Examples
1. Let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Calculating the pH
Shortcut:
For all H+/H3O+ concentrations of the form 1.*10^(a) where a is an integer number between 0 and -14, the pH is the negative value of the exponent.
Concentration =10^(-3), pH=3
Concentration=10^(-11), pH=11
For other concentrations such as 3.567*10^(-8), one cannot use the shortcut above, but have to calculate the log of the concentration
[H+/H3O+] = 3.567*10^(-8)
pH= - log(3.567*10^(-8))
This is keyed in as follows (to minimize the number of parentheses)
8 (-) [2nd][10 to x] [*] 3.567 [LOG] [=] (-)
Here you have two (-) change sign, the first is entered after the exponent of 10, the other at the end of the calculation to take the negative of the displayed result. You may notice that it is entered in the reverse order of the defining relation - log(3.567*10^(-8)).
To verify your calculation, the result is 7.447696891 or just 7.45
If you have a problem with the first (-) try entering it before you type in 8.
Hope it helps and thank you for using FixYa
And please, show your appreciation by rating the solution.
Posted on Dec 10, 2009
3 Related Answers
Anonymous
SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
how do i find the anilog on my calculator i have a texas instrument ti-30
Posted on Oct 15, 2008
gdcroft
  • 192 Answers
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
Posted on May 29, 2009
Anonymous
SOURCE: antilog for ti-84 plus silver edition calculator
"2nd" + "log"
Posted on Jun 07, 2009
How do I calculate: What is the [H3O+] of a solution with a pH of 4.5 on the TI-83 Plus
If you have the pH, and want to calculate the concentration that yields that value of the pH, you proceed as follows
c[H3O ] = 10^(-pH)
Ex pH=8.23
c[H3O ] : [2nd][LOG] [(-)] 8.23 [)] where
[(-)] is the change sign key.
Here is a screen capture to show you how to calculate the pH (first example) and the concentration (2nd example)
Sep 03, 2010 | Texas Instruments TI-83 Plus Calculator
How to use antilog?
[H+]=10^(-pH)
Exemple: let the pH=5.5, what is the H+ concentration?
Hope it helps.
Dec 07, 2009 | Texas Instruments TI-30XA Calculator
I am trying to do ph problems for chemistry and I cannot figure out how to use the log button right i keep getting an error
To use the log function press [LOG] enter the number, close the right parenthesis and press [ENTER]
[LOG] 1 [ ) ] [ENTER] gives 0.
I have a hunch your problem is not the syntax of the log function on this calculator, but the calculation of the pH from the concentration or the calculation of a concentration from the pH. So I am inserting a copy of a previous post on the question. Use it as an exemple.
Let y=10^(x) 10 to the power of x
Take the log of both tems of the equality. You get log(y)=log[10^(x)] where I used square brackets for clarity. But from the general properties of logarithms
log(b^(a)) = a*log(b)
Applied to our expression above log(10^x)=x*log10
But since we are using log as log in base 10, log_10(10)=1 so log(y)=x
We thus have two equivalent relations
y=10^x <----> x=log(y) The double arrow stands for equivalence.
If y is the log of x, then x is the antilog of y
Your question: With log_10 standing for logarithm in base 10
pH=-log_10(c) where c= concentration. Then log_10(c)=-pH
The equivalence above translates as
log_10(c)=-pH is equivalent to c=10^(-pH)
The concentartion corresponding to a pH of 7.41 is
c=10^(-7.41)=3.89x10^(-8)
Hope it helps
Oct 28, 2009 | Texas Instruments TI-30 XIIS Calculator
May 29, 2009 | Texas Instruments TI-83 Plus Calculator
Hoe do you use logarithm on TI-36X SOLAR?
Basically you first have to put your answer into scientific notation by pressing the 3rd key then the 6 key. The screen display should change to one big zero and two small zeros.
I was workinggon the same problem with a -log of a chemistry problem to get pH and I knew the answer because I calculated it on it TI-85, but we are not allowed to use graphing calulators on the exam (:-((() so I had to figure out how to do it on this one!
For example, I had pH =-log(2.828947x10^4)
On the TI-36X you change to scientific notation using the instructions above. Once the three zeros enter on the screen:
[4]
[2nd]
[10^x]
1^-04 should appear on screen, then you multiply by 2.828947
[x]
[2][.][828947]
then your screen will show the answer in scientific notation.
2.828947 in big numbers and in small numbers -04
From there you simply press:
[log]
and your answer will show up as a negative number. Just take the absolute value of that and you have your answer. Took me like 30 minutes the night before a huge chemistry exam to figure that out! Hope it helps someone!
May 09, 2009 | Texas Instruments TI-36 X Solar Calculator
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
Hope that helped))))) ^^
May 10, 2008 | Texas Instruments TI-83 Plus Calculator
Antilog in chemistry problem
pH is minus (log to base 10) of the hydrogen ion activity of an aqueous solution, or (log to base 10) of (1/hydrogen ion activity)
To get the inverse log, i.e the hydrogen ion activity corresponding to a specified pH, simply enter the pH value and press
2nd
LOG
1/x
Answer 0.001
Apr 22, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
2,066 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
