Question about Microsoft Windows XP Professional
I have a ET1161-05 machine and I put in my existing Win XP disk
I have a ET1161-05 machine and put in an Win XP Pro disk which I want to boot from. I also need network drivers but nothing so far is compatible. Where do I find all the drivers?
Posted by mcorbin on
Anonymous
    New Friend:
  • 22 Answers
That model Sir, has no available compatible drivers for Widows XP but only in Windows Vista. I'll give you the proof just follow this link. http://emachines.com/support/drivers.html.
Posted on Dec 08, 2009
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
Windows xp on 8460p
Hi Jon,
Make sure that you reformat the hard drive first before installing XP, if you are trying to install XP over the existing Operating system that may not work if you have Vista or Win7 running.
boot from the Disk to be able to start outside of windows instead of putting the disk in when windows is up and running.
Put the Win Xp dic in restart the laptop kee on tapping f12 then it should ask your where to boot select the cd/DVD this should boot from the disk directly and will be asking you to reformat the hard drive and inform you that the existing windows will be deleted, just say yes, that should go the way you want it.
Feb 17, 2012 | HEWLETT-PACKARD Elitebook 8460P
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
How can i remove windows 7 starter and install windows xp
Boot to you bios and make sure you can boot off your dvd rom first. boot off you win xp disk and follow the instructions.
First locate drivers that are compatible with your computer and win xp.
Apr 06, 2010 | Acer Aspire One PC Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
Sep 26, 2008 | Compaq Computers & Internet
Microsoft Windows XP Professional Logo
193 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
