Question about Cameras
The SD slot on my digital camera looks wider than an SD card
The SD slot on my digital camera looks wider than the SD cards are. Is there a different kind of SD card out there that is wide? I tried using the SD card for my sony digital camera and it seemed too small for the opening on the digital concept camera. It was a regular SD card, not a micro SD.
The camera in question is Digital Concepts 7.1 MGP 0804180004E10104A00...it was purchased at ToysRus
Posted by raven2298 on
Anonymous
  • 1,305 Answers
Specs says it's compatible with sd cards and MMC cards..
Posted on Dec 07, 2009
Peter Schr?der
    Champion:
  • 241 Answers
It appears to be a normal SD card slot.
The camera can handle cards up to 1GB.
Anonymous
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
As SD cards are getting higher in GIGS they are getting fatter so do you mean fatter or wider as in length and could it be an XD slot instead?
Posted on Jan 26, 2010
Card reading error
Have you tried a different SD card, or a newer SD card? If the card isn't the issue you may have damaged/dirty pins in the camera memory slot. If so, there are "cleaning" cards available that MIGHT work but otherwise, it will need to go in for repair.
Apr 12, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
The instructions say to use SD/SDHC memory cards only. I purchased an Olympus x-D picture card M+ 2GB. Is this a card I can use? I do not know what the difference is.
No, if the instructions say that it will only take a SD or SDHC card then that is what you must use. They are different shapes, with different contact layouts, and different formats. They are not compatible with each other unless the devices specifically supports it.
Here is what a typical SD card looks like: crasher35.jpeg
Compared to the xD card: crasher35_17.jpg
They generally will not fit in each other's slots.
May 29, 2011 | Olympus Stylus 5010 Digital Camera
I have 2 different sd cards 4gb that the card won't format or read because it won't format it.
The DX7630 works with MMC and SD cards. Your 4GB cards are actually SDHC cards, not SD cards. While they will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jan 28, 2011 | Kodak EasyShare DX7630 Digital Camera
I have purchased a second hand camera. When I put a 4 GB Sd card. It does not give any display
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
Jan 23, 2011 | Samsung Digimax 301 Digital Camera
I have purchase a second hand camera. When I put a 4 GB SD card. It does not give display
Why my 4GB SDcard can not work at my NIKON coolpix 5900
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 16, 2011 | Nikon Coolpix 5900 Digital Camera
What is the maximum size microSD card that can be used?
The A520 uses SD cards. SD cards max out at 2GB in size. A microSD card in an adapter looks exactly like a SD card to the camera, and microSD cards also max out at 2GB. Anything larger is a SDHC or microSDHC card. While they will fit into the slot, they are electronically incompatible and will not work. So, the short answer is: 2GB.
Dec 20, 2010 | Canon PowerShot A520 Digital Camera
How to get images off the memory card
Yes it is possible (although some memory cards are easier than others). You need a memory card reader with the correct slot for SD or SD/MMC cards, depending on your card. (There are lots of memory card types but most will include an SD slot.) You can get USB or internal card readers (which fit a 3 1/2 drive bay desktops) at most computer parts stores (Cyberguys.com, TigerDirect.com, etc). They range in price from ~$10-$60 dollars depending on the number of slots and other features.
Once you have the reader installed, place your card in the appropriate slot and look for it to come up as a new disc on your Computer. Open your Photo program and access the images from the disc. If it doesn't show up, there is a problem with the card or the reader.
In some cases, reinserting the card in the camera and using the camera to computer USB cable works better. I'm not sure why - it might be a formatting issue. (The card reader might look for the data in a different pattern than the one that the camera formatted the card with.)
I hope this helps.
Jun 26, 2010 | Nikon COOLPIX L4 Digital Camera
SD CARD
maybe the card must be a SD-micro card?
May 20, 2007 | Fuji FinePix S7000 Digital Camera
Cameras Logo
Top Cameras Experts
ADMIN Canada
ADMIN Canada
Harrie
Are you a Camera Expert? Answer questions, earn points and help others
