after installing pc suite in PC....connect ur mobile with usb cable to computer...directly it will detect ur drivers and now open ur pc suite ,it will show ur mobile...share ur pic videos and backup ur all data....all d best
It would only detect when bluetooth device when the bluetooth device is connected. It doesn't even show in the control panel until it is detected. If using win XP, service pack 3 must be installed in order to get a bluetooth cpl option.
Hello, Most modern cameras allow direct file copying.All you need to do is to 1) Connect the camera to your computer using the USB able that came along with your camera. 2) Now the pc will detect the camera and show it as a storage device,just like it would show a pen drive. 3) Now you can open the newly detected storage and there you will find the pictures taken with your camera.Look inside all folder available within the drive to find your pics. 4) Now you can simple copy the pics there and paste in on any folder/drive on your computer hard disk like you would copy any other file.i.e,simply selecting all the files you need to upload to your pc,right click and then select the option Copy,and then browsing to any folder on your hard disk,right click and then select paste.
To send pic.....from mobile 2 pc.....is possible........if ur handset has bluetooth........if u have bluetooth in ur mobile.......then buy a bluetooth stick.....which will be less cost only.....the device will b like a pendrive connect it 2 USB port......ur mobile will be detected just like other device....if it doesnt detected automaticaly......then type fsquirt in run........it will search 4 a bluetooth device.........cool.......vote 4 me......if u like.......
normally mp3 players always show on pc as a prtable device when connected with pc. the main thing is if it not detect by pc as a device. u can't transfer any music & may be it will not work again (damaged). if it detect on pc then u can use quick format option then transfer new music files & see.
thanks
What u need to do is not just turn on the blue tooth on your phone but set it to 'find me', so that other bluetooth devices would be able to locate the device. the 'find me' option is also under the blue tooth menu.
Check if the player was detected by the computer..
to check: go to device manager
right click my computer go to hardware tab and click device manager and scan for hardware changes.
a baloon will pop up if the device was already detected by the pc
however if it still not detected you must install the firmware of your device, or its driver so that you can browse its content.
TRANSFER PHOTOS
To transfer photos to your Sansa c240:
1. Open Sansa Media Converter on your PC
2. Connect Sansa c240 to the computer.
The detected Sansa c240 will list the available space and total space on the device. If more than one
device is inserted, only the first device will be supported.
3. Add the media files to be converted and transferred to the device.
4. Press “Convert” button to start the conversion process and transfer all of the files in the selected
media window and output them using the parameter setting for each media type. A convert status
box will appear showing which file(s) are being converted and the percentage of that file along with
all of the files.
