Hi, after reading you're problem, I found that you did the right thing.If you bypassed the switch and now you have power to the condenser motor but it doesn't operate, the motor is faulty, as you are eliminating the switch sending power to the fan motor. If you have power going into one side of the switch and you jumped it over, and the motor starts, the switch is at fault. So, you did the right thing! Sometimes you cant tell by looking at the switch wiring to no if it is at fault.In the field, we use jumper wires everyday to bypass components to check them out.In you're situation, both the compressor and condenser fan motor operate from this same switch, and the compressor was running. So, that tells me without having to bypass it that the fan motor is the faulty one, or the compressor would also be off. You may have to find one at a appliance parts house, or order one online. Sounds to me that you will have no problem changing this out. Best of luck to you, and Sincerely,
Shastalaker7
PS Let me no the out come.
