Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
The lamp light should NOT be RED. The lamp light should be yellow for the lamp timer warning.
There are two ways of retting the lamp timer= 1) on the TV use the vol - button. push until vol goes to zero, then keep holding it down on the REMOTE push the "split" button
the yellow light should go out indicating that the lamp timer has been reset if this fails to work, on the REMOTE, use the "PLAY" button, instead of "split". you may have to try this a few times to get it to "take". you'll know when the YELLOW lamp light goes out.
However, a RED LAMP light means you lamp is not working or missing. reseat your new lamp into the TV...and be certain the LAMP DOOR is securely CLOSED.
TV "LAMP" LED light indication flashing or staying on front of the bazel frame.Mean this tv have a dead projection lamp.The tv must have it tv projection lamp replacement.To make the tv to work again.
Try resetting the set, there is a reset on the front of the tv where the power button is located, just stick the point of an ink pen it it and it will reset itself, if this does not work make sure the lamp door is secure.
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
