Question about Emerson EWR20V4 DVD Recorder/VCR
What type of dvd do i use to record on? - Emerson EWR20V4 DVD Recorder/VCR
Posted by rousebobby on
Anonymous
    New Friend:
  • 10 Answers
Simple any blank dvd medium is fine. Depends on size of file you want on dvd either 4.7 G or a double layer. Also either + or - are fined, depends on your machine.
Posted on Dec 07, 2009
GreyAdder
    New Friend:
  • 6 Answers
I've used this unit a lot in the last four years, but have only tried a few different DVD-RW's & -R's. Mostly I've had success with Maxell DVD-RW's, mixed results with Memorex -RW's, & so far Fuji -RW's have been just fine. I think these brands of -R's should work too. The Maxell's have gotten hard to find, but I was happy with my order of Fuji's from TotalMedia.com. I've only recently learned that you need to heed the manual & use a DVD lens cleaner disc every 10 hours or so -- apparently even a mote of dust on the laser lens can destroy your recordings, or at least will cause unwatchable skips! Good luck --
Posted on Dec 14, 2009
It doesn't recognize DVD types when we want to record from TV
Check you are using DVDR+ or DVDRW and that they are blank
Jan 13, 2012 | Lite On LVC-9016G DVD Recorder/VCR
RECORDED DISCS NOT PLAYING BACK ON OTHER DEVICES
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
Oct 25, 2011 | Televison & Video
Wanting to find out what type of recordable DVD to use to record a VCR tape to use using a RCA DRC8295N model
Any types DVD dics that have DVD+R copying writing to the dvd disc to it only one time only or DVD+RW eraseable old materials buy copying some else on it.
Feb 28, 2011 | RCA DRC8295 DVD Recorder/VCR Combo
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
I'm having problems formatting discs for Panasonic EZ47 DVD recorder. Keep getting "formatting unsuccessful" message.
Now here are the types of DVDs that you can record to DVD-RAM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Now the only types that you can format are DVD-RAM, DVD-RW, DVD+RW
So first make sure you are not trying to format the wrong type of DVD. If you are using the correct type then you might want to try a different brand. Sometimes certain brands of DVDs have problems with certain players. You can also try updating your player's firmware and see if that corrects the problem also.
Jan 01, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Every disk I put in to record something says bad disk
There's very little information about your problem, like model and disks you are using. I can give you general information.
All DVD's doesn't work will all types of recorders.
DVD Types:
  1. DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-RAM, DVD-ROM, DVD+ROM.
For More In-Deph detail of DVD Formats, Enter Here.
Check what types of disk your equipment uses. Maybe needs lens cleaner or is a equipment malfunction. If it reads, then most likely is in good shape. From my experience, I have two DVD recordable setup boxes. But one only accepts DVD-RAM and the other accepts DVD+Recordables and ReWritables.
If this can't help, you can post more detail about your equipment.
Jul 06, 2009 | Daewoo DVR-06
Won't recognize Sony DVD+R DVD.
Maek sure the recorder does not require the DVD - Type disk
Dec 19, 2008 | GoVideo R6740 DVD Recorder
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Emerson EWR20V4 DVD Recorder/VCR Logo
504 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
