Question about Dishwashers
Whirlpool Quiet partner II
I had the blinking clean light, so I reset the system(thanks for that). Still no hot water. What's the next step?
Posted by leblanc_drew on
dennis dodge
  • 1,891 Answers
Ck the float / it may be stuck . / water valve may have failed . mm
Posted on Dec 07, 2009
How do you reset the control panel on a whirlpool quiet partner II dishwasher?
It should reset automatically. There could be lint buildup inside the dryer airflow inlet that is located just inside the door on the bottom. There could be lint buildup at the exhaust vent at the back on the bottom of the dryer.
Nov 09, 2015 | Whirlpool Dryers
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Dishwaer won't wash
Sounds like the impeller has frozen up or the motor burned up. Check the video below to troubleshoot.
Check your warranty,. Call manufacturer with model number and they might be able to help you. If you have to buy the motor, get the part number and do a search online. The manufacturers tend to be a bit high.
Good luck.
Feb 16, 2014 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner II dishwasher and it is stuck in the clean mode the light continuous blinks
THat means that something is wrong with the water temp. It is either not hot enough when it fills or the heating element that increases the temp it bad. To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 22, 2013 | Dishwashers
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool dishwasher Quiet Partner II: Can you help me reset the "blinking clean light" indicator? Yes or no.
shut down the circuit breaker that controls the dishwasher for 20 - 30 minutes then turn it back on.
Dec 29, 2008 | Dishwashers
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
164 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
