Question about Panasonic KX-T7630 Corded Phone
Are you able to redirect calls coming into the Panasonic KX-T7630 phone system to a mobile handset phone
Posted by kathy_walpol on
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
I can, but I'm not sure you can. On this side of the pond, we can send an inward CO call to an ICD group which has a forwarded number programmed into it. For example we usually take the owner's station and add 400 to it so his extension may be 110 and 510 is his cell phone. That way, it can be dialed from an intercom, as a transfer, from voice mail, or as a call forward argument.
Ring your engineer if you're not familiar with ICD groups and Panasonic programming. They should be able to guide you and tell you whether it can be done, especially if you have ISDN trunks.
Carl
Posted on Dec 08, 2009
INCOMING CALLS SHOW "601 DAY" ON THE PANASONIC KX-T7630, THE CALL DISPLAY IS GONE, HOW DO I FIX THIS?
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
Nov 15, 2016 | Panasonic KX-T7630 Corded Phone
How do i divert all calls from the kx-t7630 to a mobile?
You must subscribe to you Landline Supplyer for 'Call Divert Services' If Say you already Subscribe to BT.
The Proccess is access line... the on the Keypay dial... *21* (then The No; to be Diverted To) then confirm by pressing the # Key. Wait and the No; will be repeated to you.
To take off call divert access line dial #21#
When 'Call Divert' is set you will receive broken dial tone. through the Handset.
(Like a Siren)
Jun 28, 2010 | Panasonic KX-T7630 Corded Phone
Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Apr 23, 2010 | Panasonic KX-T7630 Corded Phone
I need to change the time on my panasonic kx-t7630
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 27, 2010 | Panasonic KX-T7630 Corded Phone
How do i adjust the time on panasonic kx - t7630 cheers
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 000 and then ENTER. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE. Now scroll right with the right arrow key and change the date. Now press the NEXT button on the screen and the time will appear. Set the time. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Mar 09, 2010 | Panasonic KX-T7630 Corded Phone
How do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
May 19, 2009 | Panasonic KX-T7630 Corded Phone
How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
THANK YOU
Feb 12, 2009 | Panasonic KX-T7630 Corded Phone
Programming help
THANK YOU
Dec 23, 2008 | Panasonic KX-T7630 Corded Phone
UN Forwarding calls
Pick up handset, dial 710 then #, hang up.
May 29, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
253 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
