One of the burners on my Whirlpool cooktop is not working correctly. If we cook at High temp and turn off or turn to a lower temperature the element appears to start to cool, but in a few minutes it turns on again red hot. It will burn red hot for a few minutes before finally turning off or cooling to the desired temperature.
Is this a common problem with this type of cooktop?
SOURCE: Clicking noise on cooktop even when all burners ignite
Jsut a guess - see this solution: http://www.fixya.com/support/t119696-constant_clicking_when_turned
Posted on Mar 31, 2007
SOURCE: cooktop light stays on when cool
Please be more specific. A. What is the "plate cut-out"? B. How does one access it?
Posted on Oct 15, 2007
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Posted on Nov 20, 2008
SOURCE: Need part# 786106 (coil element module) for Whirlpool cook top RC8920XRC
I have the part. New in box.
Posted on Apr 17, 2009
Feb 26, 2011 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Sep 13, 2009 | Frigidaire 31 in. GLEC30S8 Electric...
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jan 07, 2009 | Whirlpool GJC3034 Electric Cooktop
Nov 20, 2008 | Frigidaire Cooktops
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Feb 21, 2008 | Jenn-Air JED8430 Electric Cooktop
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Aug 11, 2018 | Whirlpool Cooktops
593 people viewed this question
