Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
Posted by true_texan07 on
obxnit94
    New Friend:
If you have a "FORMAT" button on your dish or cable remote use this because it worked for me
Posted on Dec 12, 2011
Shahid Electronics
  • 10,594 Answers
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Posted on Dec 06, 2009
The 55 " screen doesn't show the entire broadcast picture
Instead of trying to make the TV display the picture the right size I suggest you adjust it at the source. If it is a cable box or sat box there should be a display adjust capability to size the display to the native resolution of your TV.
Nov 03, 2017 | Televison & Video
Cannot see score bar at top of screen during NFL games
Try operating on screen adjustment command, if there is no way to adjust screen position , then it may be a faulty component inside the TV.
Is the tv still under guaranty?
Sep 07, 2008 | Sony Grand WEGA KF-50WE620 Television
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
Vertical problem
should have taken it back day 1
Dec 12, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Toshiba 50A50 missing sports score on top of image
Download the service manual and you'll find that there's a service mode that allows you to adjust convergence. Also, there's some adjustment knobs behind the right front speaker assembly
Oct 08, 2007 | Toshiba 50A50 50" Rear Projection...
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
982 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
