I've got a problem with LG secret. One of the messages seems to be stuck in the outbox folder and I can't even cancel sending it or delete it either. Although I topped up my phone credit (Telstra), whenever I want to send a txt message, the note comes up saying: not enough space for a txt msg, create a multimedia? I deleted my inbox and sent folders. Please help!
hi please see that instead of an unread message it might be a unsent message stuck in your outbox, seems you have cleaned your inbox and drafts folders but there is still something stuck in your Outbox folder
Yes you have unsent message in your outbox trying to auto sent, check your outbox folder and try to stop or delete all unsent messages and your sms will go.
I had this same problem. You need to delete your outbox. When your on the screen that says inbox/drafts/outbox etc. the outbox doesn't say that there is anything in it but it automatically saves all your text messages. You need to delete the ones in your outbox.
1)My lg k750 touch screen has become a nightmare only lower one works at will the rest are dead so what do i do? less than one year old 2)outbox hangs messages how is it solved
>lets go store location
>open outlook express>tools>options>maintenance>store folder>Copy the location
>click start >run>paste the location >Click OK
>it would open up outlook express data file with .DBX extensions
>lets make sure outlook express closed
>lets rename the outbox.dbx to outbox.old
>lets reopen outlook express> but we will loose the outbox email
when you are on your inbox or outbox press options then go to mark/un-mark and then press mark. you can scroll down the list and select the ones you want to delete.
Empty the Outbox in Outlook Express, move any messages you want to Send later to the Drafts folder.
Close Outlook Express.
Do a Search for .dbx files. Search:
Start > Search > For Files or Folders > All files and folders,
In the field for: all or part of the file name
Key in: .dbx
Below that, click on More advanced options
in the field: Type of File, select (All Files and Folders)
place a checkmark in:
Search system folders
Search hidden files and folders
Search subfolders
click Search
Locate the Outbox.dbx file and Sent Items.dbx file and delete it.
Restart Outlook Express, a new Outbox.dbx file will be created.
Send yourself a Test message to see if it leaves the Outbox.
You may need to enable Show Hidden Files and Folders to see the .dbx files. Windows XP:
Open My Computer, Tools > Folder Options > View tab,
under Hidden Files and Folders, verify Show Hidden Files and Folders is selected.
Remove the check mark for Hide Extensions for known file types. Apply, OK to save and close.
Here's the fix if when you send an email attachment from another application it gets stuck in the Outlook Outbox...
[HKEY_CURRENT_USER\Software\Microsoft\Office\Common\MailSettings] "StrictAccountOrder"=dword:00000001
Tooks us a long time to come up with it but great to have! It's fixed in Outlook 2007.
Bill www.IVDesk.com Complete hosted IT solution where we run all your applications and provide 24x7 support! Work from any Internet connection anywhere.
