Question about Sony Bean MP3 Player
Format error - Sony Bean MP3 Player
Posted by doug818 on
Curtis Sewell
  • Sony Master
  • 7,482 Answers
Be sure that you are downloading only the following formats, otherwise you will get the "format error" message:
MP3, ATRAC3, ATRAC3plus, and unprotected WMA and WAV files Good Luck, I hope this helps
Posted on Dec 07, 2009
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
Format error
Format error means memory card in camera is unstable and need to be formatted. You will lose all data/ files on memory card after format.
Format option is available in camera Menu.
This will solve your format error problem in camera.
Dec 18, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Format error.
To solve format error, go to camera Menu and select Format and press OK. This will format and delete all data on memory stick.
Apr 11, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
'Format Error'
Seems memory stick has some file error and camera firmware sense it.
Please format memory stick by going in to camera Menu, Format, OK.
Feb 03, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Format error
my problem is also the same 'Format Error'
Aug 16, 2008 | Sony NW-E405 MP3 Player
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Sony Bean MP3 Player Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
