Mitsubishi VS-50705 50" Rear Projection Television Logo
Question about Mitsubishi VS-50705 50" Rear Projection Television
My Mitsubishi VS-50705 is dark on screen, do I need to replace the bulbs to fix it? where to buy the bulbs? Thanks
Posted by mike12790 on
  • mike12790 Dec 08, 2009
    Can you tell how to fix the going out crts, i do want to fix this with many thanks...
electroman
    Genius:
  • Mitsubishi Master
  • 1,039 Answers
There are no bulbs in this set. Only 3 crts red,blue and green. crts are probably going out. repair expense will exceed value due to age.
Posted on Dec 06, 2009
  • electroman Dec 09, 2009
    Replacing the crts in a tv should only be done by a professional servicer . There is high voltage in there that you need to know how to handle.There are many alignments to be done that requires some expensive equipment. I don't mean to be rude. The crts may not be the problem and only by being with the unit and truobleshooting it could a technician determine actually what the problem is. But my advise stands from my experiance that this tv is old and would be a money pit to repair.
My tv won't turn on
OK BUDDY IM NOT A HOE FIRST OF ALL AND SECOND LERN TO SPEEK GOOF
MITSU VS 50705 SCREEN JITTERS WHEN COLD.STARTS AFTER A FEW MIN'S OF WATCHING,LASTS FOR 5 MIN'S,THEN GOES AWAY COMPLETELY ??
set tv on fire,then threw it down the stairs...
now,why would i tell you how i fixed it for 'free' ,when you
charge ''me'' for answers..hmm
1helpful
DO YOU HAVE TO REMOVE THE FRONT OF THE VS50705 TO CLEAN THE MIRROR OR CAN YOU GO THRU THE BACK?
You need to remove front screen of TV to clean the mirror or anything inside.
Check below exploded view of VS-50705 manual to have an idea...
Vertical bars and lines run up and down the screen. Need service manual or parts outlet
There is no such thing as a "vertical sweep circuit board" in that set. The vertical circuit is part of the sweep module. And BTW that type of symptom is more often a power supply filtering problem anyway.
1helpful
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Screen
Hi.
Call to Mitsubishi Service Manager
Santiago A. Bañuelos
Mitsubishi Digital Electronics America
Tel. 559-589-1290
Fax 559-589-1460
Mitsubishi vs-50705
Maybe you have a problem with the Vertical out, and you need change it.
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
