Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Hi, My Konica minolta 210 printer gives me an error msg and it doesn't print and I have the driver to re-install the it and test but I couldn't remove the old driver (it doesn't show in the add remove program) can you help me please? Asma
Posted by coldsun_84 on
Anonymous
    New Friend:
  • 15 Answers
Hi after u install u must change ur PORT to a new port form printers and fax + ur printer right click properties ports
Posted on Jan 15, 2010
Konica Minolta Di250f for Windows 7 64bit operating system??
Can not be used with windows seven. Go to this web site at KonicaMinolta Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 05, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
Konica minolta 1390mf driver + windows7
Konica Minolta in Japan don't know when the 1390mf driver will be available. Still waiting also
Wayne
Jul 21, 2010 | Konica Minolta PagePro 1390MF All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
Unable to print from after attching to dlink printer server
check the paper type in the driver, it might be setted to Letter and you are trying to print as A4 or A4 to letter.
Jun 09, 2009 | Konica Minolta bizhub 180 All-In-One...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Pcl xl error
Di183 standard m/c with GDI printer,to Print thru PCL driver u need to have Image controller installed in the m/c. So delete the printer driver & install the GDI printer driver.
Mar 13, 2009 | Konica Minolta DiALTA Di183F Copier
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
191 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
