Re: Picture will not appear from cable box to nec...
Try the signal(picture)first in television.if it is ok.check projector for right input selection.if it is not check your cable company and ask for help.
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
dear friend
for this you have to configure you display settings
right click on desktop and click on properties
now click on settings and see for the setting you have mentioned select the second display adapter appear in the dialouge box and save it
and close the dialouge box.
now you can see your contents on your projector
vote me if it helped
gagan
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
If you are using the vga input connection please take a look at all the pins and make sure none are bent this could be the reason you are missing one of the primary colors. If not check your cable pins.
if you have a cable or sattelite box, or a tv with a video output, connect the video output from the box or tv to the video input on the projector. if you have a tv without a video out, you cannot watch tv and change the channels on the projector.
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
