Samsung 710V 17" LCD Monitor Logo
Posted on Dec 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the solution? I would be very grateful for a helping hand! Cheers.
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Dec 06, 2009
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
48283
Points
381
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Anonymous
Level 3:
  • Master 6,831 Answers
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1214729
Points
16134
Hello
Here is something you can try:
Check your LCD's OSD setup menu (On Screen Display = OSD).
Mine used to give similar message whenever any program was not set to LCD max resolution. It is just a reminder by manufacturer as LCD diplay works best in its native resolution (max res). Any lower resolution and screen is 'scaled' in size to fill screen area, giving less quality picture.
Drivers allow (via CCC) to turn off scaling. This way screen image gets smaller as resolution lowered but text stays sharp and in focus. So as an example on 20" screen set to 800x600 with scaling off you get a big black border all around the screen display - but the image is sharp. (Not sure why you would want to do this but thats what happens.
Unfortunately this CCC feature stopped working in 5.13 for me.
Anyway solution for me was to turn off warning in OSD.
Realy hope this can be of help.
Kind regards
Andrea
Stan
Level 3:
  • Master 748 Answers
Stan
Master
Level 3:
Answers
748
Questions
0
Helped
268409
Points
2393
Well, do what it says - go to Display Properties in Control Panel and set your display resolution to the recommended settings. You will get a better picture quality too.
Samsung SyncMaster 710v isnt responding, keeps
Hello , this is very common problem with this model .
The problem is with main board there are two solutions:
1.Replace the main board with proper part
2.The trick you can try is to add resistor 47ohm on main board chip between two pins.
If you are not familiar with electronics do not attempt to repair it by self , go to proper service center. There is always possibility of electrolyte-shock, or high voltage shock . Hope this helps.
Fix Samsung SyncMaster 710v Not Optimum Mode Recommended Mode 1280 1024 60...
1helpful
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
How to solve a samsung 710n A tft error message not optimum mode recommended mode 1280*1024 60hz in windows xp
It wants you to set the PC video card video output to its native resolution (1280*1024 60hz). Are you running the PC resolution on this mode? otherwise you can turn off the resolution warning by going into the monitor on-screen setup menu to turn off the resolution warning.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
6helpful
3answers
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Samsung 710v 17'' lcd problem
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
2helpful
6answers
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
