3'' solid black vertical line just left of centre on my 50'' panasonic plasma can i get rid of it
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
WHEN i TURN MY TV ON i GET VERTICAL LINES FROM SIDE TO SIDE BUT THE CHANNELS CHANGE AND VOLUME VORKS. WHAT COULD IT BE? PANASONIC SAYS THE LCD IS BAD, I DON'T BELIEVE THEM BECAUSE THEY TOLD ME THAT BEFORE AND I TOOK THE SET APART AND FOUND A CABLE GOING TO THE LCD PARTIALLI HANGING LOOSE.
CAN YOU MAKE SOME SUGGESTIONS?
