Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How can i clear error c-0521 - Konica Minolta bizhub 350 All-In-One Laser Printer
Posted by reza257 on
  • Andrea Lock
    Andrea Lock May 11, 2010
    HelloOk, if you are receiving the error code c-0521, try the following steps, this worked for me. Start by opening the front door where the toner is located. On the right side (Where the hinge is) next
    to the black toner and drum unit there is a plastic pannel/cover. In
    the lower portion of that pannel there is a hole where a trouble reset
    switch is loacted. With a flashlight you may be able to see it. You are
    meant to use a pin to push the button. You do
    this while the machine is still powered on and displaying the code. As soon as you
    press the button the copier will clear the code and start warming up. Thats it! If you are uncertian of the button placement you can take out
    three screws from the pannel and loosen one screw from the pannel above
    it and and pull the pannel off the unit. You will see the board and it
    is the button on the (left), as there are two of them. Though you only
    have access to the one through the cover.
    Kind regards Andrea
steve p
    New Friend:
  • 44 Answers
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note : On the7915/7920,after opening the front door,it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Posted on Dec 07, 2009
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Need to find the bedrails for a Bassett CRib 5925-0521
Call 1.800.308.7485 Bassett. It is a Bassett Furniture dealer in Virginia. They are very helpful. I was told to use standard full size rails with hooks on each end and that would fit. :)
May 26, 2012 | Bassett Baby Gear
What is the universal remote code for RCA DVD?
UNIVERSAL REMOTE CODE .
Find all the code you need for your universal remote.
Universal remote codes DVD Player
Aiwa = 0641, 1912
Anam = 1913
Apex Digital = 0672, 0717, 0755, 0794, 0796, 0797,
0830, 1100, 1915, 1937
Audiovox = 0790
B & K = 0655
Blaupunkt = 0717
Blue Parade = 0571
Broksonic = 0695
Cambridge Soundworks = 1916
Cinevision = 0876
Classic = 1917
CyberHome = 0816, 1019, 1023, 1024
DVD2000 = 0521
Daewoo = 0784, 1918
Denon = 0490, 0634
Emerson = 0591
Enterprise = 0591
Fisher = 0670, 1919
GE = 0522, 0815, 0717
GPX = 0699, 0769
Go Video = 0715, 0783
Gradiente = 0651
Greenhill = 0717
Harman/Kardon = 0582, 0702
Hitachi = 0573, 0664
Hiteker = 0672
IRT = 0783
Initial = 1931
Integra = 0627, 1924
JBL = 0702, 1926
JVC = 0558, 0623, 0867, 1901
KLH = 0717, 0790
Kenwood = 0490, 0534, 0682
Konka = 0711, 0719
Koss = 0651
Lasonic = 0798
Magnavox = 0503, 0675, 1914
Malata = 0782
Marantz = 0539
Microsoft = 0522
Mintek = 0717
Mitsubishi = 0521
Nesa = 0717
Norcent = 0872, 1923
Onkyo = 0503, 0627, 1924
Oritron = 0651
Panasonic = 0490, 0632, 1362, 1490,
1907, 1908, 1909, 1910
Philips = 0503, 0539, 0646, 0854, 1914
Pioneer = 0525, 0571, 0632
Polk Audio = 0539
Proscan = 0522
Qwestar = 0651
RCA = 0522, 0571, 0717, 0790,
0822, 1022, 1913
Rotel = 0623
Rowa = 0823
Sampo = 0698
Samsung = 0573, 0820, 1932
Sansui = 0695
Sanyo = 0670, 0695, 0873
Sharp = 0630
Sherwood = 0633
Shinsonic = 0533, 1931
Sony = 0533, 0864, 1533, 1903, 1904
Sylvania = 0675, 0821
Technics = 0490
Theta Digital = 0571
Toshiba = 0503, 0695, 1045
Tredex = 0799
Urban Concepts = 0503
Venturer = 0790
XBox = 0522
Yamaha = 0490, 0539, 0545
Zenith = 0503, 0591
Feb 03, 2012 | RCA Televison & Video
Code 0521 is the read out. What does it mean? I cannot find it in the catalog.
P0521 error indicates a problem with the oil pressure and/or sensing system Possible causes: Low oil level or motor mechanical fault
Open or short oil level sensor circuit condition
Poor oil level sensor electrical connection
Faulty oil pressure sensor The most likely cause is a faulty oil pressure sensor/switch Locate the sensor/switch and insure the wiring to the switch is in good condition ( CLEAN nad a solid connection) Replace the sensor
Feb 04, 2011 | Chevrolet Impala Cars & Trucks
Necesito los codigos para dvd
DVD Apex Digital 0672 0717 0794 1056 0755 0797 1100 0796 1061 DVD Axion 1072 DVD Blaupunkt 0717 DVD Blue Parade 0571 DVD CineVision 0876 DVD Curtis Mathes 1087 DVD CyberHome 1024 1023 0816 DVD Daewoo 0784 DVD Denon 0490 DVD Dual 1068 DVD DVD2000 0521 DVD Emerson 0591 0675 DVD Enterprise 0591 DVD Fisher 0670 DVD Funai 0675 DVD GE 0522 0815 0717 DVD Go Video 0744 0715 0783 DVD GPX 0699 DVD Greenhill 0717 DVD Hitachi 0573 DVD Hiteker 0672 DVD JVC 0558 0623 DVD Kenwood 0490 0534 DVD KLH 0717 1020 DVD Koss 0651 DVD Lasonic 0798 DVD Magnavox 0503 0675 DVD Marantz 0539 DVD Microsoft 0522 DVD Mintek 0839 0717 DVD Mitsubishi 0521 1521 DVD Nesa 0717 DVD Norcent 1003 DVD Onkyo 0503 DVD Oritron 0651 DVD Panasonic 0490 1762 DVD Philips 0503 0539 0646
Jan 13, 2011 | One For All URC-3021 Remote Control
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
Bell pvr 9242 hard drive failure
YOU NEED TO TAKE IT OUT AND PUT IT IN AGAIN BUT MAKE SURE ITS IN RIGHT
Dec 30, 2009 | Televison & Video
How can i clear error code C-0521
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bassett Southampton Crib Directions
THE DIRECTIONS FOR BASSETT SOUTHHAMPTON CONVERTIBLE CRIB (model 5925-0521) ARE LOCATED *INSIDE* THE WARNING LABEL ON THE WIRE CRIB BASE. The warning label is an envelope that holds the direction packet. I was confused, too--I thought they hadn't included them with my crib! Hope that helps!
Jun 08, 2008 | Bassett Cottage 3-in-1 Crib
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
579 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
