Question about Remote Starter with Keyless Entry
I need to find an installation diagram for a 2001 Dodge Durango for installing a ungo rs 10 remote starter
Posted by davis17 on
Anonymous
  • 344 Answers
My 2004 Dodge Durango has a brand new battery and starter. It also has a security system on it. Everything works it just won't turn over. What can I do?
Sounds like the immobiliser is working well. You have to tape a key near the ignition switch when you have a remote starter installed.
Aug 12, 2015 | 2004 Dodge Durango
Instructions on how to remove REMOTE STARTER on Dodge Durango
look in owners manual for how to activate valet mode.
Mar 23, 2013 | 2005 Dodge Durango
I have a 99 Dodge Durango and I installed the remote starte with keyless entry and I am haveing a problem withe trans when it starts in the remote mode. The trans makes a noise like a seloniod is running...
what type of remote starter did you install? I have run into a particular brand that had published a bad diagram drove me nuts.Make sure the wires in diagram are wired to its correct corrisponding places.
Dec 27, 2009 | AutoCommand Remote Car Starter Add-On
Clarion ungo alarm model 5100
Can't seem to locate a manual. Just get into the wiring under the dash and follow the larger wires from the alarm brain and cut each wire, one at a time, from the factory ignition harness them tape. Start with just the starter wire to see if that fixes the issue for now. If this problem just started, check to see if there is a tach wire that runs under the hood to a coil or injector. If this wire is disconnected the remote start won't see the car is started and will continue to crank the starter.
Nov 03, 2009 | Ungo S670 Car Alarm 2way LCD & 4butt Rem
Brake diagram and rear drums diagram for 2001 dodge durango, trying to install new drums and brakes
Visit the autozone.com website and register the car information. It's free and will give you access to an online repair manual for the car. Information regarding the braking system should be available there. It's a handy resource. Hope this helped and best wishes.
Sep 11, 2009 | 2001 Dodge Durango
Need a wiring Diagram for a 1999 Dodge Durango so i can install a remote start system. Or what colors I need to look for.
Most auto parts stores such and advance auto parts and autozone sell repair manuals. I prefer the Haynes manuel wich has the wireing diagrams printed in the back of the book and acuratley tell each color code
Aug 03, 2009 | 1999 Dodge Durango
Installing a ready remote starter
http://64.85.6.118/diagrams/diagrams.asp use this site to rekognize wiring harness at the ignition switch or related wiring
Mar 12, 2009 | 1996 Dodge Stratus
Radiator and Coooling assembly
check out this website, enter vehicle info, click on radiator support, they have some good diagrams that will hopefully help u. let me know if this is what u need . www.moparonelcom/partsmoc.htm countrycurt0
Oct 03, 2008 | 2001 Dodge Durango
Remote Starter with Keyless Entry Logo
186 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Boulden
SSN-MM3
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
