Question about Pioneer Televison & Video
I was given a pioneer tv sd-p5575 and i dont have
I was given a pioneer tv sd-p5575 and i dont have the remote. i conected a dvd player and it plays the dvds. however i cant see any cable channels. the cable line is conected to antenna 1 but cant see anything.why? can i program it manualy from tv itself or can it be done using a universal remote?
    New Friend:
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Posted on Dec 06, 2009
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
AFTER CONECTING A DVD I CAN'T FIND A CHANELL TO PLAY THE DVD. I HAVE CABLE TV
Your DVD is selected by using the TV remote button which cycles thru your TV's inputs such as INPUT SELECT or VIDEO or a button like these. Put a DVD in and press PLAY on the DVD player, then press the button on the TV remote to select the DVD player. If you reply with your TV brand and model, I can tell you exactly which button on the remote to press or you may discover it yourself.
Mar 17, 2011 | Televison & Video
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
Apr 08, 2010 | Pioneer DV-333 DVD Player
Pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Dec 12, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
HOW TO PLAY DVD WITHOUT REMOTE
try pressing stop while at the menu. then stop again. then hit play. that works for most dvd players
Sep 28, 2008 | Pioneer HTD-510 System
Hooking up Pioneer DV 250 DVD player through Directv Satelite Receiver
i dont know what hooks up were on my tv i have rca jacks but cant seem to get it all to play , hell i dont even know what channle to put the tv on, i do have a cable box to
Sep 17, 2008 | Pioneer DV-250
Region free?Toshiba SD-140E
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)
I found this for other Toshiba SD dvd players, yours was not listed but might be worth a go.
Oct 25, 2007 | Toshiba SD-140E DVD Player
Televison & Video Logo
108 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
