The samsung refrigerators is 58 degrees f. and food has spoiled. I unpluged the refrig for a couple of hours and reset. Call a services rep who said ice was building up inside the cabnet and suggest using a blow dryer to rid the ice. The problem is still happening and I had a throw spoiled food away several times. The refrigerator will not stay cool, even when I reset.
The hair dryer is a bad temporary fix. The question is why does it continue to freeze up. there are a few possibilities. One is an over or under charge of refrigerant which is unlikely. It would have done this from day one. the other is that the evaporator coil is icing up due to some dust or dirt. this slows down the air flow across the coil and then the ice eventually blocks off the air flow. The fridg is like your house. It has a supply air and return air side that must be kept clean and free from obstruction. also one of the fans may not be working. This will definitely stop the airflow
1.
The first thing you must know is that your refrigerator should be
set at 37-38 degrees. Anything at 40 or higher and you are risking
food born illness (food poisoning) or spoiling your food. Place your
magnetic thermometer in the refrigerator.
2.
Set your dial on your refrigerator to the second lowest setting. (If
your refrigerator is already equipped with a digital thermostat,
simply set it for 37 or 38 degrees and do not move on to the next
step)
3.
After 2 hours, check your thermometer reading. If your reading is 38
degrees, there is no need to go higher and you are ready to put your
groceries in. Be sure not to open and close your refrigerator during
these two hours or your temperature reading will be incorrect.
4.
If your reading is higher than 38 degrees, move your dial up to the
next coldest setting and repeat the steps every two hours until you
reach the correct temperature for your refrigerator.
5.
Once you have reached the correct refrigeration temperature for your
refrigerator, place the magnetic thermometer in the refrigerator
permanently and watch for changes.
Typically, your
refrigerator temperature will need to be adjusted with the seasons,
a higher setting in the summer and a lower setting in the winter.
