Question about Euro-Pro Shark GI490 Iron
Hey there, Please guide me for the wire connections for Shark GI490 Iron along with the color code so that it can work back again. I will appreciate you assistance.
Posted by physiojay on
Graeme Ross
  • 1,512 Answers
The advice given here is totally incorrect. Please ignore Azraelsrl solution. Being incorrect makes it very dangerous!!!
Blue or black = Neutral red or brown = phase green or green/yellow = earth.
If in doubt, you should get a qualified electrician to replace the cord to your iron. Getting it wrong... can easily kill someone!!!
regards robotek
Posted on Apr 13, 2010
  • Azrael SRL Dec 24, 2010
    Actually as long as the grounding wire (the yellow/green) is correctly identified there is no danger whatsoever in switching the faze and null wires. If it would been otherwise you would be in mortal danger every time you would plug it in the mains.
Azrael SRL
  • 11,800 Answers
The wires from the power cord ? If yes then: blue = faze, brown = neutral, yellow and green = ground.
Posted on Dec 06, 2009
DISASSEMBLE SHARK G1465D ELECTRIC IRON
there are 4 screws that you can see and two more under the large rubber stand off at the bottom. I also need you post the wire in the back because I took mine apart and now don't remember the position of the wires
Jan 23, 2012 | Euro-Pro Shark GI490 Iron
It suddenly quits...i have to juggle the line cord to have a power.
Sounds like a loose connection from the screws inside the housing of the iron. It is a wee bit of a bugger to get INTO this iron, but with a little patience, and a screwdriver (phillips, the + one) you should be able to get to where the power cord connects to the terminals inside the iron. Loosen, and retighten the connection. If the wire seems 'worn', you may have to cut it back a bit and score off some of the plastic, and re-wire.
Mar 17, 2010 | Euro-Pro Shark GI490 Iron
Can't get the Iron to come on. power light is on.
sensor is not working properly please check and replace the unit
May 21, 2009 | Euro-Pro Shark GI490 Iron
Shark GI495N cord sparked and burst into flame
shark website for instructions and number
May 07, 2009 | Euro-Pro Shark GI490 Iron
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
Shark Euro Pro Iron turns of while ironing
what makes the water spit out of the iron and make my clothes wet
May 05, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
375 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Andrew Taylor
Andrew Taylor
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
