Question about Dell Inspiron 6000 Notebook
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Posted by mikemccullou on
IQUIT
  • 3,940 Answers
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Posted on Dec 06, 2009
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
May 03, 2012 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
Compaq Presario 6000 desktop powers-up for 1 second
check your ramm also use s start up disk to check your drive boot sector
Jan 14, 2010 | Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron will not boot
Most likely you will need to replace the motherboard. Roughly $100 on Ebay.
Mar 20, 2009 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
264 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
