Wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
