My env2 isn't workingg the outter screen is all white and the inner one is all black i can recieve texts and calls and all that well basicallyy the phone still works just not the screens [never get an env2 they ****''/] Whatt should i do as a short soultion til i can get a new phone..?
To delete single messages on an ENV2 with broken inner screen:
1) Go to your message inbox on your external screen to find the message you want to erase, but don't open it.
2) Open your phone and hit OK (to open message)
3) Hit the top left silver button, then OK.
Wait a few seconds for it to delete. If you know you have multiple messages right in a row you can skip step 1 and the first part of 2 (open your phone).
The problem with your phone is just flex problem, the flex
on the screen of your phone is weak or worn out, this is a common
problem among slide or flip phone.
What you need to do is to
replace the flex on the screen of your phone, you can get this done by
going to any local phone repairer within your vicinity to help get it
fix or replace.
Once the flex is replace, your phone display
problem is solve and the screen will start displaying.
sir is it blinks with white screen only or blinks with white screen then shut down? -if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery. -and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
i had the same problem i dropped my env2 and the inner screen went black. i tried 2 fix it but just ended up getting a new phone. you can try 2 live on the outside screen or i was able 2 bend the screen and get it to work for a while. i hope i was helpful
walk outside with your phone in hand. with one hand, hold the phone firmly. with the other, grab a baseball bat. step out into your yard, or maybe the yard of a neighbor you don't like. throw the phone straight up in the air, then grab the bat handle firmly. swing away at that bad boy. fetch the phone and repeat the process if you are not fully satisfied with how your phone functions after one whack. hope this helps
