I can't get my camera to automatically focus on upclose objects. It always used to work but it now doesn't. A small frame used to come on the screen to give me a chance to auto focus without the zoom.
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
The Raynox 250 is an adaptor lens that makes a "macro lens" from a standard lens. Normal you only can focus a standard (zoom) lens say about 2 feet in front of the camera lens and anything beyond that. Small things, would be very small in your frame. With a macro lens, you can come very close to an object, because they can focus from a few inch in front of the lens. With the 250 you "transform" a standard lens to a macro lens, by just clicking it on the front of your lens. Read the manual, how to do that.
You than can make macro pictures, but great chance you have to focus in the MF position. When you have focused, you should be able to take a picture in automatic (green camera symbol) when you want to change things, you only look what shutter time and what aperture the camera choose and from that you can go into manual mode to make the aperture smaller (greater f number) and an other shutter time.
For macro photos you always should use a tripod, because shutter times can be a bit long and every movement of the camera will be greater than the object you try to get sharp in the picture.
There are several factors that can contribute to getting better focus and improved results.
1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds.
2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls.
3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus.
4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure.
5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
