Question about Metra Ford F 150 Truck 1999
Dash lights are not working - Metra Ford F 150 Truck 1999
Posted by adamswca on
Anonymous
    New Friend:
  • 3 Answers
Check fuses under the hood or under the dasboard (under steering column)
Posted on Dec 05, 2009
2001 dodge ram 1500 2 wheel drive all dash lights not working interior fuses checked all ok odometer light works
most dash lights can be dimmed or switched off check this first, then trace the wiring from the switch to the dash lights for a bad connection.
Oct 03, 2016 | 2001 Dodge Ram 1500 Truck 2WD
My dash lights dont work at all
The tail lights are usually on the same fuse as your dash lights. Check to see if you have tail lights. If they are on and it's only your dash lights that don't work, check the dash dimmer switch for a fault.
Jul 18, 2012 | 2002 Mitsubishi Galant
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
Feb 19, 2012 | 1992 Buick Century
Lights or fuse for my speed odemeter guage and heater/air conditioning system
These lights for the dash are controlled by a rheostat instrument control dimmer switch next to the main light switch for the headlights, it is either turned off (have seen this dozens of times) or it is defective. Below is a picture of the switch assembly I speak of. The thumb wheel next to the knob is the dimmer control.
Feb 13, 2012 | 2000 GMC Yukon XL
Dash and interior lights do not work
Dash lights are on the same fuse as the tail lights. Dash lights not working is an indication that the tail lights are not working. The first thing to check is that the tail light fuse is not blown. Most of the time replacing the tail light fuse will restore both the tail lights and the dash/interior lights. If this is not the case you may have to trace the wires and look for a broken or unplugged wire in the harness.
Nov 18, 2011 | 1994 Nissan Quest
No dash lights 1995 Jeep. I have no dash lights. My interior lights work, brake lights work, console lights dont work, stereo lights work, high beam indicator works, blinker indicator works, everything...
Look for fuse panel under or either side of dash. Another location may be similar in engine bay.
Fuses probably labelled. Available at motor shops, garages etc.
If out of your experience then probably not expensive to ask auto electrician where to look. Many are cooperative and may tell over the phone or counter.
May 01, 2011 | Jeep Grand Cherokee Cars & Trucks
Dash lights do not work.....checked fuses. no dash
WELL IF YOU HAVE DIGITAL DASH YOU HAVE TO REPLACE IT.SOME DASH CLUSTER HAS SMALL REPLACEABLE BULBS THEY CAN BE REPLACED.
Jul 21, 2010 | Cars & Trucks
My dash lights are not working the gauges fuse is
good be dimmer switch, but only if all dash lights are out,like radio heater control, cig light,if those still work then i would say its bulbs.
Oct 03, 2009 | 1990 Chrysler Imperial
Dash lights and tail lights work when they want
the occasional not working leads me to believe it's loose wiring or a short in the wire somewhere
Jul 30, 2009 | 2004 Jeep Grand Cherokee
Metra Ford F 150 Truck 1999 Logo
232 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
