2007 Honda Pilot Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi Having trouble removing cabin air filter on a 2007 honda pilot
Anonymous
Level 3:
  • Master 571 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
Answers
571
Questions
0
Helped
155874
Points
1187
Remove the four screws on the air filter hood (driver side, behind battery) using 5/16" socket. No need to remove screws all the way. Lift plastic hood just enough to reach air filter. Electrical connector can remain. Slid out old air filter. Insert new one. Replace hood, and tighten the four screws.
If the filter is tight, wiggle it left-right when pulling the filter out.
Where is the cabin air filter on a 2007 Honda Accord?
The two air cabin filters are located below the glove box, and hidden behind the dashboard knee panel.
They are quite difficult to reach. Search elsewhere on fixya for replacement procedure, i think i posted the instructions. Keep me posted
6helpful
How to change cabin air filter honda pilot 2007
1.remove the glove box. 2.Cut the plastic cross brace in the glove box opening with diagonal cutters in the area shown, and discard it. 3. Remove the bolts, the srews, and the glove box frame. 4. remove the filter lid from the evaporator, then pull out the dust and pollen filter.
8helpful
4answers
Where is the cabin filter on a 2003 honda odysseey
The cabin filter is located behind the glovebox.
First lower and remove the glovebox
If it has not been changed before, you will need to cut the plastic crossbrace behind the glovebox.
Once out of the way, unbolt the steel reinforcing frame behind the plastic and set it aside.
The cabin filter is mounted vertically behind it.
See images for further explanation:
10helpful
How to replace cabin air filter in 2003 pilot
Step 1 Take everything out of the glove box on the passenger side. Squeeze the black clips on either side of the glove box interior to free it from its retainer and pull it toward you. It will glide forward on hinged arms. Lower it as much as possible so it's out of your way.
  • Step 2 Identify the gray plastic bar that runs from left to right across the bottom of the glove box opening. This is a piece of plastic molded to the rest of the glove box assembly, but it covers up a removable bar that is mounted directly in front of the cabin air filtermag-glass_10x10.gif case. You'll have to cut this plastic bar off with a razor knife to proceed. Fortunately, this isn't too difficult; just cut carefully and steadily, and make your cuts as close as possible to the ends of the bar.
  • Step 3 Remove the metal bar you uncovered in the previous step. It is screwed into the glove box assembly with Phillips head screws on either side.
  • Step 4 Open the cabin air filter case, which is the large plastic case on the left side off the glove box opening. The hatch will come all the way off when you open it.
  • Step 5 Take the old air filter out of the case and throw it away.
  • Step 6 Look at the arrows on the filter and the arrows on the filter case that indicate the direction of the air flow. Slide the new filter into place so that the arrows are both pointing the same way.
  • Step 7 Put the lid back on the air filter case and reinstall the metal bar you removed in Step 3.
  • Step 8 Push the glove box interior compartment back into place and listen for the snapping sound. Put the glove box contents back, close the lid and you're done.
  • 7helpful
    3answers
    Can't find the ''cabin air filter'' on my 1996 Honda Odyssey
    A 1996 Honda Odyssey is not equipped with a cabin air filter. If I was looking for a restriction in the cabin air, the first place I would look is on the inlet side of the A/C condensor. ALL cabin air travels through the A/C condensor ALL of the time. (The heater core only sees air when the temp door is not directing the air around it and always after it has been through the condensor first.) I have seen gunk as hard as concrete clogging the condensor just from layers of dirt that collects on the wet coils then dries.
    2helpful
    2answers
    Location of cabin air filter? How to replace cabin air filter?
    check behind glove box at top of black coil housing, look for door/cover
    27helpful
    2answers
    2008 honda pilot cabin air filter
    This solution pertains to a 2008 Honda Pilot...To replace the cabin air filter which is located on the passenger side of the vehicle behind the glove box: Open glove box and remove stored items...while sitting in the passenger seat, pull towards you on each of the two clips on the left and right side of the glove box...this will cause them to become loose and the glove box will tip out completely exposing the inside of the dashboard. (Alternately...carefully pull towards you on the top center of the glove box which will cause the left and right side stops to pull away from the edges and allow the glove box to tip out) Here it gets tricky...the box holding the cartridge for the cabin air filter is the large black box on the left side behind the glove box The filter fits in a removable tray vertically inside that box. A pressure clip at the top of the box allows the vertical cover to be removed exposing the tray with the Cabin air filter... BUT!!! There is a plastic bar an inch or so high which has been placed there by the manufacturer to prevent most from changing the filter without the service department being involved. This bar must be cut with a sharp sheetrock knife or hacksaw and discarded, (it will not be reinstalled). Then there is a flat metal bar behind the plastic bar that can be removed using an 8mm socket and a phillips screwdriver. There are 2 8mm screws and one phillips head screw on each side that must be removed in order to remove the metal bar. THEN you can remove the cover to the cabin air filter box, pull out the tray with the filter (note how the filter is in the box so the new one can be placed the same way) reinsert the tray with the new filter and replace the tray cover. All other steps to finish the job are obvious as everything is the reverse. Actually the whole process is a lot of trouble and unless you are determined to change the filter I would recommend not doing it.
    3helpful
    Air/Cabin filter Maintenace
    Simple! No tools needed! Take everything out of glove box. Squeeze sides in until glove box can swivel down. You will se a black cover that has arrows on it showing the direction of air flow. Squeeze the side latches on that cover and it slides right out. The casing is "keyed" so it will only go back in one way. If you can read the wording on the cover, you have it right.
    1helpful
    Change cabin air filter
    Open the glove box. Remove the damper from the glove box then let the glove box hang down
    Remove the dust and pollen filter assembly from the evaporator case.
    Remove the filter (A) from the housing (B), and replace the filter.
    Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the evaporator
    Top Honda Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Honda Expert? Answer questions, earn points and help others
