I press the menu and the input button and it blinks 2 times pause then 2 more times what does that mean??
My problem is i press the power button and the tv wont turn on i see a solid green light for 5 sec then a clicking noise and the the light is gone
On front of set press and hold both the menu and input buttons for at least 5 seconds and release both, power light will blink a two digit error code like 2 blinks, 2 blinks, and pause and repeat several times.
Let me know error code and I will tell you what it means.
If power light comes on and then goes off do the self check this set has:
when light goes off and front of set press and hold both the menu and Input (device) buttons in at same time for at least five seconds and release both buttons.
The set will (the power light) blink a two digit error code like, 2 blinks, 2 blinks, a pause and repeat the code several times.
2,2 is most common error code, let me know what error code if any you find and comment here and I will tell you what it means.
The self check is designed to narrow down where a problem is.
IF POWER LIGHT COMES ON AND THEN GOES OFF: DO THE SELF CHECK THIS SET HAS: ON THE FRONT OF THE SET PRESS AND HOLD BOTH INPUT AND MENU BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH.
POWER LIGHT WILL BLINK A TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and then it will repeat the code 4 more times.
Let me know if you get a blink code and I will tell you what it means.
If this information was helpful, rate this solution as very helpful as I do this here for free.
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
