Crock Pots & Slow Cookers Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you steam rice & if you can, how, I bought it used & ni directions with it. ModelC4450 Serial# 1230 600 watts
Anonymous
Level 3:
  • Master 581 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
Answers
581
Questions
0
Helped
192699
Points
1559
HERE IS THE LINK TO RIVAL YOU MAY FIND A MANUAL CLOSE TO WHAT YOU BOUGHT BUT AT ANY RATE YOU CAN CONTACT RIVAL.
http://www.rivalproducts.com/help.aspx?helpNav=5
What else can you do with the rice cooker if you don't cook rice?
You can steam vegetables in your rice cooker. Just make sure you watch the vegetables they will cook faster in your rice cooker than normal.
Rice Cooker Timer
I had one, it's just takes practice, time the batch and use a measuring cup, this will help you get dialed in to being the master rice cooker, that hides within you Grasshopper !
Jay the pool pump motor repair guy Longwood Florida
5helpful
I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
Pressure cookers rely on pressure and steam,
Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
TickMagnet
2helpful
2answers
What is the temperature of low setting and high setting where can I get an instructions for Model KC271B
The manual is available here: http://www.sharkclean.com/manual/KC271B_REV_0804B.pdf . The high and low settings are more like those of a microwave rather than a direct temperature setting. On high, the slow cooker uses full power (35 watts). On low it uses 1/2 power.
I hope this helps.
(In one place it says 34 watts. In another it's 340 watts.)
1helpful
Where do i get a manuel for Rival steamer/rice cooker model # C4450 serial # 0213
Your manual for the Rival Automatic Steamer/Rice Cooker 4450 can be downloaded from this site:
http://micromatikal.dlinkddns.com:8000/cust/4450.pdf
Sorry someone has not responded sooner.
I need a instruction manual for a rival automatic
The manual is available from http://kitchen.manualsonline.com/manuals/mfg/rival_1/4450.html
How much water will i need to fill in well to cook rice in rival4450
11/2 cups of water to 1 cup rice. For softer rice use 2 cups water to 1 cup rice.
2answers
Lost power cord to my wolfgang puck 5-Quart Pressure Cooker
I believe the power cord is just like the power cord to a desktop computer. You can buy one at Best Buy
45helpful
5answers
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Top Rival Crock Pots & Slow Cookers Experts
Paul Carew
Paul Bade
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
