Question about Kenmore 57029 Side by Side Refrigerator
The ice freezes in the holder and doesn't dump into the drawer and the motor clicks.It starts to dump and freezes and doesn't dump into the bin. I replaced the filter yesterday and still isn't working. The water part works and I was able to move the wires for the celanoid that operates the ice cube maker and moved the wires over and held them while my wife operated the the water switch and water went up to the ice cube maker so I feel the celanoid is good but I am not getting juice down to the celanoid. Since then we have made a few ice cubes but they freeze together before they dump into the bin and we hear a clicking noise. model #106-626636
Posted by oln1326 on
Sal De
  • Kenmore Master
  • 2,699 Answers
You have a bad ice maker,there is a heater on the ice maker that separates the cubes before they dump out and it sounds like yours is not working
Posted on Dec 06, 2009
The ice maker is making a slight clicking noise and not dumping ice. why?
it sound as the tray should be look into. It can be worn out or crackrd
Jul 03, 2014 | Jenn-Air JCD2389G Side by Side...
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
On my refrigerator has a code er 1 f
What do I need to do to fix my refrigerator
Nov 15, 2012 | Kenmore Refrigerators
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
I have a kenmore 106.53593200 fridge the ice maker not making ice but i can feel its running
As long as your freezer will freeze water, your ice maker will make ice. All the ice maker does is supply the water, then dump the ice after it freezes.
So, that narrows it down to: 1) Either the ice cubicles are not filling with water, or 2) The ice is not dumping into the bin after it freezes.
To check for #1, you should be able to look into the ice cubicles to see if they're filled with water (or ice). If they are, go to #2. If not, you've probably got a defective water valve.
If the cubicles are full of ice or water, but don't dump out, the most likely culprit is the cubicle heater, which slightly heats the walls of the cubicles so that the ice can be more easily ejected into the bin. Unless you're VERY mechanically inclined, this is a job best left for an appliance repairman.
Jun 27, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice dumps into the drawer but, sticks to the dispenser coil
The heater on the bottom of the ice maker is probable not comming on and warming the ice so it can be dumped. Some icemakers are rebuildable and you can replace the element, some arent.
May 12, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Nov 21, 2008 | Whirlpool Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
963 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
