Plantronics Audio 345 Headset Logo
Posted on Dec 05, 2009
Issue with Music Going Through Headset...
I have recently obtained a new Plantronics .Audio 345 Behind-the-Head Stereo Headset, which comes with an audio jack, and a microphone jack. (Not USB)
What I normally do is go into my audio settings, set the sound playback to the monitor ("Realtek HD Audio rear output"), and the voice playback to the "line in/mic in" option. But my other microphone headset used USB...
I don't know how to get the music to go through the monitor and the voices to go through this headset. I have tried, but there seems to be no detected "Line In/Mic In" option - everything is going through the headset... It's driving me nuts!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
184
Points
Wires broken plantronics .audio 628
Strip the wires back further. There make be more broken wires. Put all of the colors together and include the bare copper wire. That wire is the ground and there will be poor performance or no performance if the headset is not wired properly.
How do I listen to music through the bluetooth
Listen to music with the Plantronics Explorer 220:
Unfortunately the Explorer 220 was not designed for music, it does not have the technology built in to stream audio. Headsets must have the Bluetooth A2DP profile and technology to be able to stream music. Like the Plantronics Voyager Pro+ and BackBeat models. Here are the links for these below.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/ipod-mp3-mobile.html
Good luck from Headsets Direct - 800-914-7996.
Recently my headset does not turn on. I thought perhaps it needed to be charged, but even when plugged in none of the lights come on. After charging over night, it still did not turn on. It worked fine...
Have you seen this FIXYA Link?
Plantronics audio 995H wireless headset not charging when plugged into...
Or could be your tiny "POWER" button-switch has gone bad"? Or perhaps a actual battery 'hard failure'?
Here is part of the text:
The 603443 next to its replaced counterpart. The new battery is a 850 mAh lithium polymer battery while the original is a 500 mAh lithium ion. Sweet!
See the Link about Battery Replacement...
While you are in there try a Q-Tip with a tiny-tiny dab of contact cleaner sprayed on the Q-Tip... now try to apply some cleaner right to the Power Switch CONTACTS.
*** BE SURE TO USE A CONTACT CLEANER THAT IS "PLASTIC SAFE"!*** and with silicone is better.
Plantronics 995H battery upgrade
Anthony
Pairs but won't control player to hear music
Try contacting Plantronics directly at 1-800-544-4660 x 5538. They will help troubleshot and determine if you have a defective headset or if you're experiencing a compatibility issue.
Good Luck from Headsets Direct!
Can i connect my Plantronics Discovery 925 with my ipod touch? and how if i can
Your headset is a monaural device, and, as such, bears bluetooth profiles HSP (HeadSet Profile) and HFP (HandsFree Profile) only, which are suitable solely for handling phone calls. The iPod Touch is not a phone, though, for what it must lack those profiles. It does have A2DP (Advanced Audio Distribution Profile) and AVRCP (Audio/Video Remote Control Profile), though, which are meant for stereo music streams. In order to have a bluetooth headset paired with your iPod, you better purchase a stereo pair out there. There are lots of brands and models available.
You know, for some platforms there are some applications which are able to route all audio sources to a monaural bluetooth headset. I don't know if there are any of such softwares to be picked up from Apple's app market. You could search for it, if you want, but be warned that such arrangements use to result in pretty poor sound quality.
Please, let me know if I can help you any further.
Regards,
Carlos
3helpful
Can one get the plantronics audio 995 USB headset (with microphone) to work with the PS3? The headset uses 2.4GHz, not bluetooth, so it's not a bluetooth pairing issue.
I believe it should work...
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
3helpful
2answers
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
Music
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the new Plantronics M50. The Plantronics M50 is a new model which is now available and is in the $47 range.
Below is a link to the M50.
Plantronics M50
Good luck from Headsets Direct!
1helpful
Plantronics p590 + BB Pearl
Pearl 8100 can not output media audio to Bluetooth. Another BB might.
How do i listen to music on my plantronics bluetooth that is connect to my samsung blackjack
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the Plantronics Voyager Pro+ and the new Plantronics M50. The Plantronics M50 is a new model which is now available. For more information these two new models, please see the links below.
Plantronics M50
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
