Question about Motorola TLKR T5 Two Way Radio
Motorola TLKR-T5 room monitor doesn't work well.
The room monitor doesn't work well on my new radios.It catches not often my voice even the radio is set on maximum sensitivity. Anyone can help?
Posted by sklirokaridi on
3 Related Answers
Anonymous
  • 24 Answers
SOURCE: Motorola Tlkr T5 two-way radio can send but not receive
unit a is it in tone mod or diff. tone then b
Posted on Jul 14, 2009
Anonymous
  • 12 Answers
SOURCE: one of my motorola TLKR T5 handsets is stuck on
Hold down the "SEL" button to unloch it and then search for the manual on http://www.radios-uk.com/manuals.htm
Posted on Dec 28, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: My motorola TLKR T5 keeps
Hi.
Remove battery from both handsets to reset them ensure that batteries are fully charged. If problem persists, try removing roger beep. Press and hold the up arrow key while turning the
radio ON to turn on/off the roger beep.
Here a manual:
T5 Manual.book
Posted on Aug 29, 2010
I have 2 Motorola TLKR-T3, I haven't used them for a few months but now I replaced the old batteries with new ones and one is not reciving but transmitting, and the other one is transmitting but not...
Try to google or contact maker for
reprograming codes or buttons to hold down
or a web site to download it from an hook them
to computer an load. Sounds like a program
prob
Jun 01, 2014 | Motorola TLKR T5 Two Way Radio
Motorola TLKR T3 one way not working but Monitor works...
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Nov 20, 2012 | Motorola Radio Communications
Hi, i have 2 TLKR-T3 and i cant tune it ,so what can i do? and how can i reset it? thanks in advance
Try setting the radio back to a simple mode of operation. Shut off all special features such as the sub-code (interference eliminator code), VOX, room monitor, and call tones. Go to just one basic channel, such as channel one. Then check to see if the radios talk to one another. If not, check your battery packs, as it takes more energy to transmit than to receive. Swap battery packs and see if the problem moves to the other radio. And lastly, get a third radio involved to see if one of your radios is simply defective.
For your convenience here is a link to the user guide: http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Best regards.
Aug 31, 2011 | Motorola TLKR T5 Two Way Radio
My Motorola TLKR-T3 won't work properly. Both transmitters-receivers work only in monitor mode. I have downloaded the manual and I made with high accuracy the step to set the devices properly, but nothing...
i had them for 5 years.
and they were just great.
in 6 months the one after the other did the same thing.
motorola is trying to tell us that we have to buy a new pair.
they sould know that i will not buy motorola again
Apr 01, 2011 | Motorola TLKR T5 Two Way Radio
My TLKR-T3 does not work. One of them is possible only receive menssagem ( Receive the transmission ). So it is not possible to transmit zero messanger. Seems that the microphone is not...
Check your programming. The frequency and code must be identical on the two radios. Here is a link to the user guide http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
The description you give is indiciative of the code being set differently between the two radios. For basic operation set the code to off (zero).
Best regards.
Nov 04, 2010 | Motorola TLKR T5 Two Way Radio
TLK3 T3 Motorola permanent static noise
The "MONITOR" is probably stuck on. You can go to
http://www.mods.dk/manual.php?brand=motorola and login (its free) and download the manual and look for how to turn off the "MONITOR" function.
Nov 02, 2009 | Motorola TLKR T5 Two Way Radio
Jun 07, 2009 | Radio Communications
Motorola TLKR T5  Two Way Radio Logo
426 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Jane
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
