Question about Vector 955 Radar Detector
My beltronics vector 955 radar detector displays a H and a voltage reading whenturned on and then when entering the programing menu it says BLIND OR beeps like crazy and turns itself off
Posted by mikewhite82 on
Anonymous
    New Friend:
I have the same problem. did you find a fix?
Posted on Jan 10, 2011
Take apart 955 beltronics
There are 2 screws you need to remove. The first one is in the corner of the base (flip it over and you will see it). The second screw is under the Beltronics sticker on the base, right below the first hyphen in their USA phone number. If you rub your fingernail around that location, you should feel the depression. I didn't remove the sticker, I just stuck my screwdriver over the sticker and unscrewed it through the sticker. Hope this helps.
Mar 28, 2012 | Vector 995 Radar Detector
I NEED USERS MANUAL FOR BELTRONIC VECTOR XR950 RADAR DETECTOR
You can download the detailed user manual from the following link.( http://www.beltronics.com/manuals/980950man.pdf ).Please don't forget to rate me if satisfied.Good Luck.
Jun 08, 2011 | BEL 950 Radar Detector
I bought it at a pawn shop, whenturned on, it says calibrate. How do i do that?
Hold down the "Brt" and "City" buttons as you power the unit on. This will reset the unit to it's default settings. It worked to restore mine to operation.
Dec 01, 2010 | Vector 955 Radar Detector
I have a Beltronics Vector LR. It is probably
Get a new one with X k Ka and laser protection
Sep 21, 2009 | Vector 965 Radar Detector
Service required
This message is generated only after a Bel or Escort radar detector has repeatedly encountered problems while trying to self-calibrate its radar detection circuitry. The Service Required message literally means that you must send in your RD for service since there is nothing that can be done to fix whatever the problem is short of sending it in for factory service. At least it will come back working like brand new!
Mar 06, 2009 | Vector 955 Radar Detector
BELTRONICS 940
This is a somewhat common problem that occurs when a strong voltage spike while starting your car damages the radar detector. Bel can fix your RD. Once you get it back, always start your car first before powering on your radar detector. Likewise, power off your radar detector before turning off your car's ignition.
Nov 09, 2008 | Vector 940 Radar Detector
Faulty Buttons
Return to Beltronics for repair. 1-800-341-2288.
Jun 14, 2008 | Vector 955 Radar Detector
Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
Jun 17, 2007 | Vector 985 Radar Detector
Vector 955 Radar Detector Logo
536 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Michael Thomas
Michael Thomas
Karl Kittsteiner
Kardoc
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
