Question about LG Vu CU920 Cellular Phone
I NEED THE 16 DIGIT CODE TO UNLOCK MY LG CU920
Posted by perrolanudo1 on
Dorendra Singh Pukhrambam
  • 763 Answers
How to enter Unlocking Codes for LG Phones for Various U.S
Below are instructions that work for most network providers.
How to Unlock LG (most models):
1:Insert not-allowed SIM card
2:Power on the handset- phone will display “phone restricted”
3:Select “Cancel” - phone will display “phone restriction code”
4:Enter the SIM unlock code
5:Select “OK” - the handset is now successfully unlocked
How to Unlock LG KG245 (Vodafone Australia)
1:Insert a Vodafone Australia working SIM card.
2:Ensure the phone is charged and then switch the phone on.
3:Optional Step: If the SIM card has a PIN, enter your PIN number
4:Wait for the phone to power up then enter 2945#*7101#
5:Select Menu , then go to Settings > Security > SIM Lock > Network
6:Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7:The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Unlock LG KG800 or TG800 Chocolate:
1:With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2:Go to: Settings>Security>SimLock>Network
3:Select deactivate. Enter the unlock code,
How to Unlock LG C2000:
Insert non-Cingular SIM card
1:Power on the handset - phone will display “phone restricted”
2:Select “Cancel” - phone will display “phone restriction code”
3:Enter the SIM Unlock code
4:Select “OK” - the handset is now successfully unlocked
How to Enter Unlock Codes on LG F2250:
1:With allowed sim card in the start menu type: 2945#*3311#.
2:Handset shows saved, then return to startup screen
3:Press Menu key, choose Settings > Security > Sim Lock> Network eactivate, handset will now show ‘Enter NCK’
4:Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1:Switch ON your phone with a not allowed SIM card.
2:Compose: 277634#*#.
3:Go to menu “SIM Lock”.
4:Enter the unlock code, which you can buy any online store .
How to Enter Unlock Codes on LG U8110:
1:With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2:Select ‘Sim Unlock’ menu #
3:Enter NCK code then validate
Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1:With a not allowed sim card enter Pin code then validate, type: 277634#*#
2:Shows test menu
3:Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4:Handset shows ‘Enter NCK’
5:Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1:To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2:Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1:Insert non-Cingular SIM card.
2:Power on the handset. Phone will display “Invalid SmartChip”
3IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4:In Idle screen, enter 159753#*#. Phone will display “Enter NCK, Remaining 5
5:Enter the 8 digit SIM unlock code, which you can buy any Oline phones.
6:Select “OK”. The handset is now successfully unlocked
How to Enter Unlock Codes on all other LG cell phones:
Switch ON your phone with an allowed SIM card
Then compose:
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
Go to “Menu” and then to “Settings”
Then select “Security”
To finish select “Network Provider” and select “Deactivate”
Enter the unlock code, which you can buy Online store unlock-cell-phones.
If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
2:Enter 2945#*88110#.
3:The phone will then prompt ‘Unlock sim’. Press OK.
4:The phone will then prompt ‘Network Unlock’. Press OK.
5:The phone will then prompt- ‘Input Network Control Key’. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
6:It should give you the message: Success.
7:Come back to the main screen and Enter 2945#*88110#.
8:The phone will then prompt unlock sim. Press OK.
9:The phone will then prompt Network Unlock/ Lock but if you scroll down
10 :you will see a message Enter SP Lock. Enter SP Code.
Then press OK.
How to Enter Unlock Codes on all other LG KE970 Shine:
1:Switch ON your phone with an allowed SIM card
2:Then compose: 2945#*9701#
3:Press CALL.
4:It should you ask you for the code.
How to Enter Unlock Codes on all other LG TU720 Shine:
1:Put in a non-allowed SIM, phone says invalid SIM card
2:Now enter *#865625# then enter your 16 digits code.
How to Unlock LG KG800 Chocolate Without a Code (not reliable):
1:Insert SIM from the network that it is locked to.
2:Turn on phone.
3:On home Screen, slide up phone.
4:Type 2945#*#
5:ENG. Mode menu should appear.
6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
7:This will reset the phone back to before the phone was locked to a network.
8:The phone will automatically restart (the network logo at start up will not change).
9:Now insert any SIM card and the phone should turn on normally
10:The phone is now unlocked and you can customize the setting as you like
How to Unlock LG Vu CU920
June 11th, 2008 by Eric
On the AT&T Network, to unlock the LG Vu or CU920, it’s pretty simple:
Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
Enter *#865625# then the 16 digit unlock code*
Device should say: Network Lock Deactivated
Phone may automatically reboot
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
Posted on Dec 05, 2009
Anonymous
  • 4 Answers
I came to this site first hoping to unlock my Vu for free. I followed the instructions on here but saw that it only got me to the point where I enter the 16 digit code. Turns out the code is specific to each phone and isn't available for free.
I was able to get my code for dirt cheap though. The guys over at http://www.globalunlockcodes.com are selling them for less than $2. Code took about 15 minutes to arrive, and I'm able to use my T-Mobile card now.
Posted on Mar 11, 2010
Anonymous
    New Friend:
  • 31 Answers
Dont Worry You Can solvethis easily
with the help of unlockcodes you have to type it through the keypad ............................
and you can over comeproblem easily ...........
you get the code fromofficial code provider itself
Click Here To Get Codesto unlock your phone
Posted on Jul 04, 2010
Anonymous
    New Friend:
  • 10 Answers
Hi You can unlock your LG CU920 mobile. For that you need a unlock code. The unlock code can be purchased from the site http://www.unlocking4u.com/unlock-your-phone/rs6wp2/ at low cost.
Posted on Dec 19, 2009
Anonymous
Once you unlock your lg vu can you use a virgin mobile sim card in it?
Posted on May 19, 2010
2 Related Answers
Anonymous
  • 131 Answers
SOURCE: 16 digit unlock code for lg vu cu920
call AT&T and tell them to help you unlock it for free
this is the number 1-800-331-0500
Posted on Jul 24, 2010
rhylton44407
  • 60 Answers
SOURCE: I need a 16 digit
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website. This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked. Hope this helps.
Posted on Sep 05, 2011
How to unlock my Lg Vu CU920 for free?
call att and give them your phones imei which you can find on your phone.(take out battery and it should say imei somewhere write down that number)call att at 888 387 6270 tell them you want to unlock your phone then they will transfer you. if you ask them about unlocking your phone they will ask you for the imei give it to them and they will give you a 16 digit code. http://www.mobileslate.com/blog/how-to-unlock-lg-vu-cu920/
then go to the website to see how to unlock it
Jul 04, 2011 | LG Vu CU920 Cellular Phone
I need the code for a cingular lg vu cu920 so it will work with a tmobile sim card
Mar 22, 2011 | LG Vu CU920 Cellular Phone
I locked my phone somehow
hi..
  • Enter the below code number
  • Enter *#865625#
  • Enter the 16 digit unlock code and select "OK"
  • The 16 digit code can be obtained by calling AT&T Technical support and given the representative the IMEI number.The IMEI number for your specific device can be obtained by the following:*#06#
  • Then it will be unlocked easily..
Jan 05, 2011 | LG Vu CU920 Cellular Phone
I Forgot My Security Code?
On the AT&T Network, here is how to unlock the LG CU920 (screenshots below):
Enter *#865625#
Message Displayed: SIM Unlock Process
Select “OK”
Select “Unlock SIM”
Select “Network Unlock”
Enter the 16 digit unlock code*
Select “OK”
Re-enter the 16 digit unlock code
Select “OK”
Your phone is unlocked.
Phone may automatically reboot.
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. The IMEI number for your specific device can be obtained by the following: *#06#
You will need this number in order to obtain the Subsidy Unlock Code from AT&T.
hope it helps
Sep 07, 2010 | LG Vu CU920 Cellular Phone
Jan 16, 2010 | LG Vu CU920 Cellular Phone
I need the 16 digit unlock code for my phone
The 16 digit unlock code it where you can unlock your phone to run on any network. meaning if you have a t-mobil phone or at&t once you unlock it you can run it on either.
The truth is the best way to get a free unlock code is contact what ever carrier the phone is locked to.
by law they have to give you the unlock code free of charge. The unlock code changes depending what the imei code is. you can find this code under the battery.
just be sure to call on a diffrent phone cause they will walk you though a series of steps to unlock it.
please rate me
Nov 08, 2009 | LG Vu CU920 Cellular Phone
How to unlock a lg cell phone
You can unlock the Lg phone using the unlock code and instructions.You can get that from the site unlocking4u
Aug 29, 2009 | LG Vu CU920 Cellular Phone
I NEED YOU UNLOCKED MY PHONE LG CU 920
Fist call AT&T for your specific unlock code. Then follow the directions at the site below.
Read more: http://www.mobileslate.com/blog/2008/06/11/how-to-unlock-lg-vu-cu920/#ixzz0Pc1CNoNb
How to unlock lg vu c920 and get better themes
Ok this is the only way i know how to do it, i have had a phone lock before and all you have to do is call the manufactor of the phone and get a unlock code..
May 29, 2009 | LG Vu CU920 Cellular Phone
Unlock
i need the 16 digit code to unlock my phone can you help?
May 26, 2009 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
3,813 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
