Question about MA Audio M1900XE Car Amp
Amp burned out but fuses still good?
I actually have ma audio m700xe but this was the closest one i can find to it.
i have a 1000watt ma audio amp and a 300watt spx amp and at first i just had the 1000 watt amp hooked up to two 12 inch subs idk what watts but its the pair that come with the amp ma subs.
and when it was by itsel it was extremely loud i had to keep the bass db in the car on -10 i got a splitter for the wire from the power to the battery to hook the other 300 amp up for the door speakers
after i got it all hooked up the bass was no where near as loud if it was on 0db it still wasnt as loud as it used to be on -10
so i hooked everything up like it originally was and it never got as good as it was also i noticed the 300 watt subs sounded better hooked to the subs so i hooked the 1000 watt to the doors and tweeters
then today, four months later i was driving and i all of a sudden the doors went out and all i could hear were the subs i thought it was a bad ground but when i changed the song it would play fine then smoke started coming from my back seat and trunk i got home and checked it everything looked fine
but now my ma amp will not show any signs of power, power light or protection light and my spx amps power will not turn on but when i disconnect the ground the protection light comes on other than the protection light no other signs of power and nothing is coming out of any speakers
grounds ar good the big fuse 6 in away from the battery is good and the 25 fuses in the amps are all fine
what happened
Posted by msp252 on
  • Anonymous May 11, 2010
    You can't know if the power/ground connections are good without using a multimeter to confirm that you have the proper voltages. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Anonymous
    Scholar:
  • 84 Answers
This is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Posted on Dec 13, 2009
What type of fuse should I use I have a 1000watt power acoustik
Ohm's Law says watts / volts = amps, so 1000/12 is 83+change -- damn! I hope you have a big, phat alternator! So fuses have to be rated somewhat higher than device load, you need a 90 amp or 100 amp fuse -- what style I couldn't even begin to guess, normal automotive fuses don't go that high.
If this is a new install, make sure your power wires are heavy enough to handle the load. A fuse's job is to blow before the wiring catches fire. The longer the wire is, the thicker it must be. Electrical fire is a catastrophe so make sure your wiring is adequate -- I know it's hard to believe but the power wire is actually more important than the speaker wire!
Jun 28, 2015 | Power Acoustik Car Audio & Video
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
How you hook up 15 inch kicker cvr show diagram please
Here are a few wiring diagrams to get your started.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 01, 2010 | Kicker Car Audio & Video
XM-2165GTX Car Audio Amplifier: i have a kenwood 1000watt amp model # kac-7204 i h...
I would try to remove the top cover of the amp and you might be able to push them out from the inside. Just a shot in the dark.
May 16, 2010 | Sony XM-2165GTX Car Audio Amplifier
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
Amp shutting off
your amp is likely over heating.Does it have enough air space around it? You may be over driving it does your head unit have variable out put? if so try lowering the output volume to the amp
Hope this helps...........Good Luck!
Dec 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Whats the RMS on my 1000watt 4ch amp???
hi
Ive done some research and i haven't found any conclusive ending however the best i can do is tell you the round about RMS which is approx 200 to 150 unbridged.
Dec 17, 2007 | Rockwood XR-3973 Car Audio Amplifier
Kicker solobarrick...still not working...
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
MA Audio M1900XE Car Amp Logo
Top MA Audio Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
