Question about Estate EED4300SQ Dryer
I hooked up wires as described. I smell elecrical
I hooked up wires as described. I smell elecrical fire and smell smoke when the unit is turned on.
  • 5,911 Answers
If the dryer has been sitting for a while, that may just be dust or lint that has gotten stirred up inside the dryer and ended up on the heating element. This is normal and it will go away. This often occurs after the dryer has been moved or cleaned.
However, just in case, you may want to review your power cord installation one more time. The following link explains:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Verify your installation paying particular attention to how to you have terminated the Ground and Neutral wires. Make sure the terminals are tight and not loose. Loose connections can cause arcing and excessive current which results in burned wiring or melted insulation. If it is correct, make sure you don't have any heavy accumulations of dust or lint inside the dryer cabinet. If the odor does not go away within a day, stop using the appliance and let me know. I hope this helps you.
Posted on Dec 05, 2009
6ya staff
SOURCE:
My hotpoint tumble dryer almost caught on fire the house was full of smoke can l claim
Only if you can prove that the fire/smoke was caused by a machine defect and not a lack of cleaning the unit out once in awhile.
Jun 20, 2016 | Hotpoint Dryers
Why does alarm activate when there is no smell of smoke or fire not a battery operated unit 120v hard wired unit
The unit probably needs replacing (every 10 years by code for 120V smoke alarms; NFPA 72). Note that most 120V devices are of the ionization type and must be disposed of appropriately. The label on the under side of the device often has instructions. Also try searching for your model on the manufacturer's website.
Sep 15, 2014 | Home
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
As describe earlier, my dryer started smoking, and maing a burning smell from behind the drum. There is no evidence of lint buildup in the exhaust, and the dryer still starts smelling as if it is on fire...
i just had this problem. Did you notice the lint buildup under the lint drawer? Well, there is no way to recover that lint, it is not accessible by the consumer. So the lint bits get sucked in to the out take which actually pulls across the hot element. The "solution" is to replace the element and the parts surrounding. It is very expensive, and does not resolve the issue. The lint will continue to be drawn across to that area and build up and become a fire hazard. I am about to try Bosch for a solution, but that is what they have told me for now. Eventually this make/model of dryer will burn someone's house down. I am very glad I was home when the smoke detector went off. I will have to get a new dryer.
Aug 04, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Stadt J90 Heater electrical buring smell when unit fires up smell goes away after 5 - 10min for a day or 2 then comes back. Check but no signs of fire or smoke or burnt area. Unit is old but works well...
Hello
Could be your fan blower motor overheating.Normally you wont see any smoke or burning from this motor.
There are sealed bearings in these motors that go bad and cuase a strain on the motor.Also the windings could be clogged with dirt.
Have a look at the motor after you run for a little while.IF the motor is hot to the touch have it replaced.
Apr 12, 2010 | Heating & Cooling
Frigidaire window unit with heat and a/c smoke & burning smells
Hi, Anytime you turn a unit on like this and it smells and smokes, something is wrong. Did it smell as though it was electrical burning? Usually the blower motor is the first motor to go as they collect all of the return air and dust from the air and clog up the windings. They get hot and start to smoke, and you will know due to the smell of electrical wiring. I would turn it back on and see if it starts up and runs. If the motor hesitates in anyway, turn it off, or unplug it.If it is wired directly into a box, find out where the breaker is. If you are in fear of it catching on fire, call a air conditioning company out. I have seen them smoke like crazy but never had one catch on fire, never. I would turn it on, it will trip the breaker if the motor fails. Just watch it closely. If you can pull the front cover off and then turn it on, you may be able to see where the smoking is coming from, a motor ect.
Sincerely,
Shastalaker7
Dec 30, 2009 | Heating & Cooling
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
Went to a family dollar with a roof top unit and at the time could only check right above the drop ceiling, where there was a return and supply flex and a piece of square duct going through the roof and a...
sounds like a smoke detector to me. usually they just break the red or the green through a relay, if it smells smoke. could be dust burning off the heat strips first use, or you could get on the roof and find burned wires or motor. lots of old wires burning up with heat strips kicking in this time of year. i usually have em turn off alarm so fire dept wont come and turn to max heat and burn off the strips , measure amps, check wires, and all relays etc. you may have to bypass smoke detector till done. then return to correct "as found" wiring and reset alarms. hopefully no call backs. good luck.
Nov 21, 2008 | Heating & Cooling
Estate EED4300SQ Dryer Logo
101 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Mike
jimorris77
Are you an Estate Dryer Expert? Answer questions, earn points and help others
