Audiovox AVT-1475 13" TV Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a 12v 4amp power supply - Audiovox AVT-1475 13" TV
Anonymous
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Dec 04, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
210
Questions
Helped
76823
Points
620
Look on amazon web site if you have old power supply you can use model number on it
if not try the model number on the appliance
hope this helps MERRY CHRISTMAS
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
995
Points
6
If your looking to get one on the cheap. See if you have a local Computer Surplus Store. alot of times you can find boxes of power supplys in all power ranges.
-Dog
1helpful
Bosch power box, no 12v for radio or for charging or to 12v power jack when plugged into 120v ac. Radio works when 12v supplied to 12v power jack. Can 12v power supply be fixed
Most likely the bridge rectifier in the power supply inside the radio opens, sometimes there is a fuse. If it is blown then you need to locate the reason it blew. The problem is contained in the AC circuits since the radio works OK on 12 external volts. It can be fixed.
2helpful
1994. Why is there no power on fuse that controls cluster lights, a/c and heater controls, cigar lighter light and ash receiver light, radio lamps and overdrive?
Looks as if it is a 4amp fuse and power comes from the headlight switch. Do park lights work? Looks as if 20amp fuse to headlight switch controls park lights and possibly power supply through switch to 4amp fuse. This diagram is for a 6cyl and should be the same as an 8cyl. Hope it helps
2answers
Why tcl42u22 has no power
Panasonic tc-l42u22 4amp fuse blows replace 2 diodes nte#116 or nte 552 600v 1 amp silicon rectifier fast recovery
Do I use a 12v 4AMP DC charger to recharge my Mastercraft Jump 900-AMP starter compressor?
the less amps you can use and the more time you have the better. If you can charge it on 4 amps all day, thats better than say 20amps for a few hours
I need a power supply for a 57-c3 monitor. 12v dc 85w
I guess you could be looking for something like these
http://www.coywood.co.uk/lcd-power-supply-flat-screen-mains-adapter-adp-65db-12v-7a-2222-p.asp
http://www.power-adapters.co.uk/12v-dmtech-4-pin-power-supply-adapter-p-4668.html
http://ezlaptopadapters.com/12v-7a-4-pin-power-supply-adapter-p-4006.html
I can't find where to plug the mains cable into a proview em-170 780 monitor that I have just been given
It's in the connector at the end of the monitor cable; you need a 12v 4amp positive-inside-negative adaptor.
3answers
X2gen MW19R user manual
Maybe they put more volts on it, because of the cable length. About putting the manual on Fixya. I do not know how you would do that. I know that you can have a little more volts and be okay but not enough is bad. Are you sure it is the correct cord?
1helpful
3answers
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
