Increase Efficiency with a Paslode Nailer
With Paslode
making a foray into the market with their trademark gas-fired nail guns, today they
have ruled supreme on construction sites with the amazing power tools. Now,
they have carried the idea forward with the Paslode nailer. It is a framing nail gun with all the common
advantages of the previous models such as easy setup arrangements, continuous
nail delivery and user friendly design which helps all framing projects as well
as minor weekend tasks. In comparison to the other brands, Paslode answers the
demand of customers with their sensible innovations on the nail gun which is
already a stunning performer.
The Paslode pin gun is more comfortable to
use with the slip resistant rubber hand grip. This reduces hand fatigue even
for all those day framing jobs which is a major advantage. An intelligent
streamlined model helps accommodate the gun on joists, roof trusses and center
studs. Another benefit is the recovery time in between the charges. It gives
you the chance of having more nails in the timber. Although not as high speed
as the air driven guns, the gun can deliver many nails within a short while,
offering increased productivity at work and a bigger firing rate whenever
required.
You can easily
drive your nails in hardwood along with a better overall performance. You can
take out the battery easily and recharge it with this high performance gun. The
nose point can be adjusted in several angles which is another unique feature of
the Paslode. Moreover, the spikes are amazingly gripped in the wood. Among the
other benefits is the less amount of pressure that is required for application to
the device when used. The gun is also suitable for use in awkward positions. The
drive setting is an amazing feature as Allen keys and wrenches are not required
for customizing the height of the nails.
The heavy
duty rafter hook has been designed so that it can be placed on the rater other
than merely hanging off the step ladder or tool belt, the Paslode increases the
efficiency of your work. You can save time by eliminating chores like pulling
apart hoses and compressors and organizing them. It also saves labor costs. The
nail gun is ideal for all lumber sizes and variations of framing and can be
used for structural purposes as well. The battery charger that is provided with
the gun requires a couple of hours for complete charging.
Resource Box: The Paslode nailer is your best bet for increasing
your work output. The Paslode pin gun
helps reduce downtime.
You need a new actuator
I have in stock
airnailerparts dot com
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
if you are talking about the top of the gun its a cooling and exhaust fan and its normal to get a little smell. not all the gas might be burned in the combustion process
