If the front panel display on your Technics SA-AX6 is not turning on even though you have replaced the display board and verified that the ribbon cable is not broken, there may be an issue with the power supply or the main control board. It's possible that a component on one of these boards has failed, preventing the display from receiving power or a signal. You may need to take the receiver to a professional repair shop for further diagnosis and repair.
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
