Hi, this message usually appears in the following circumstances:
SOURCE: Epson scanner V100
Check the calibration strip to make sure it isn't soiled. This can cause streaking in your scans. Also check the glass where the paper is. Make sure it is clean as well.
SOURCE: epson v100 scanner
uninstall the program again, the software was not fully removed or go to
start
run
type regedit
go to hkey local machine
go to software
look for your software and delete that file
restart the computer
then install again your software
cheers
SOURCE: Epson V100 flatbed scanner power cord
There's a shop in the UK or Sweden called Clas Olsen that sell a range of multi headed adapters, you have a pack that has the usual ones you see and they have a pack for other adapter heads and one of them fits the V100. How do i know? Cos I bought one for my scanner but it will set you back by £25.
SOURCE: can you install a epson perfection v100 photo
yes, by downloading its driver from the internet, try connecting it first to your pc if it can be detected otherwise no need to install the driver
