Question about Mitac Mio 338 Pocket PC
My mio 338 won't go past the align screen. I keep on touching accurately the target but it doesn't help.When I touch the fifth mark, it comes back to the first one. It's like it's not processing correctly or something. What can I do? Thanks for all the help you'll provide me with
Posted by roulala on
3 Related Answers
Anonymous
  • 16 Answers
SOURCE: problem dell x50v {align screen}
A problem I have seen countless times on the DELL pocket PCs. Check the corners of where the touchscreen go UNDERNEATH the plastic housing. Sometimes when dust or debris collect here, your touchscreen has a difficult time calibrating.
Posted on Apr 17, 2009
Anonymous
  • 45 Answers
SOURCE: Hi My mio 168 wont get past the align screen no
From my experience, the only solution is to change the display
Posted on Apr 20, 2009
Anonymous
SOURCE: Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Posted on Nov 18, 2009
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
My touch screen is off the mark
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 12, 2011 | Computers & Internet
In my htc p3300 smart phone they are showing align screen from 1 hour it is asking tap the target firmly and accurately at each location on the screen.
Remove the batrtery while the Phone is turned on.
Reinstart.
it will reload defaults
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | HTC P3300 Smartphone
I cannot get past the align screen page is there a way of bypassing it?
If it just keeps asking you to calibrate, then that means the touch screen is faulty.
Oct 24, 2009 | HP iPAQ RZ1710 Pocket PC
I have problem htc align screen
Thanks a lot. It worked perfectly:)
Sep 22, 2009 | HTC Touch HD Smartphone
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
Mitac Mio 168 won't go past ALIGN SCREEN
The touch panel on the LCD unit is defective and needa to be replaced with a new Compleet new LCD+TP unit.
If you have a screen gaurd on your Touch panel, try to remove it and check again, if it doean't help ---> new LCD+TP unit
Nov 15, 2007 | Mitac Mio 168 Pocket PC
Mitac Mio 338 Pocket PC Logo
79 people viewed this question
Top Mitac Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
matt
matt
Larry Ng
Larry Ng
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
