1998 Cadillac Catera Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My radio, interior light, power lock don't work
Hi can anyone help me, my radio, interior light, power lock don't work on Cadillac 98 catera. when I turn on windshield wipers radio, interior light and power lock works. wipers have to stay on for the electronics to work. my power adjusting seats work with with or without the windshield wipers. checked all fuses under the streering wheel and some under the hood there all good, nothing burned out. problem started when i had a buned out left head light, since then the electronics died. I replaced the light bulb and fixed the head lights they work fine now but the electronics still don't work.
Colin Stickland
Level 3:
  • Cadillac Master 22,516 Answers
  • Posted on Dec 04, 2009
Colin Stickland
Cadillac Master
Level 3:
Answers
22516
Questions
Helped
6998135
Points
66324
Weird this one ,but what i normally do when confronted by a mixed up electrics and that is to run a new feed wire and disconnect the original
02Ford Taurus windows windshield wipers locks wont work
Sounds like the wire you used for power was oon the circut for all those other things, or if you pulled the fuse box down to hook radio up through the fuse box, you may have grounded out some wires, or knocked them loose. Use a test light or voltmeter and make sure you have power at the fuse box for wiper,dashlight, trunk release, door lock fuses.
Where to put windshield wiper fluid in 1998 Cadillac Catera?
There should be a filler tube just behind the grill.The bottle is behind the grill way in the front of the vehicle.Have someone push the washer button and follow the noise of the pump motor.Hope this helps.Good luck.
2answers
I took a stock RDS radio out of my 98 catera and put it in my 97 catera... it reads "Locked-THEFTLOCK active" on the screen. Please help
If you never entered a lockout code for your radio, youll have to take it to the dealer to get them to clear it out.
The radio or dome lights will not work unless the windshield wipers are on
Take it to the garage and ask them to check the car's Electrical grounds. When a ground gets corroded, loose or rusty, it can play havoc with the electrical system of the car. For example, in my friends car, when you would turn the radio, and heater on, the Windshield wipers would go. I thought it was funny, but it does get annoying. But sure enough, it was a faulty ground wire.
1helpful
In my 1997 Cadillac Catera if I turn my lights, windshield wiper, or Air on the battery goes down slowly untill it dies...I have bought a brand new battery also replaced the altenator!! What else could it...
It sounds like the ground from the alternator is bad. Have the connections cleaned and restore the ground. if that doesn't work have the alternator tested. Sometimes they do fail straight from the shelf. Hope this helps. Good luck.
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
